Car stored for winter
#32
Question for you guys. First year owning my 911, I have it in storage since late Nov and thinking of taking it out in the next day or so. What do I need to do? Do I just connect the battery lower the tire pressure and just drive it around?
Thx!
Thx!
#34
had no choice as it is underground. asked around first before doing so including dealer and was told it is not ideal but ok to do so.
so what do i need to watch for when bring it out?
#35
you will get all the error codes on PASM etc etc etc. drive it around the block and most will clear. park for a few minutes and re-start & everything should be restored - even station memories on PCM.
rubbish about not unplugging battery -
#39
nothing to it - i unplugged my 987 for 3 winters and just finished re-connecting the turbo battery today after more than 4 months.
Correct, you will get a PSM error code (not a PASM error), but this will clear within a < 1 mile.
You'll need to reprogram (easy) your windows too.
#41
Nothing wrong with disconnecting the battery for the car other than the PITA of having to reset a bunch of things when you reconnect it. I'd be more concerned about the damage to the battery. I spend my life consulting for dealerships and you would be amazed at how many warranty claims get put through to the manufacturer for "defective" new batteries. More often than not, it turns out that the battery was stored improperly (cold damp concrete floor, as an example) and sulfated. Yup, some parts depts use maintainers on factory fresh batteries to protect their inventory.
Just buy a proper maintainer and plug it in; 10 sec job and be done with it.
#42
The GT3 has an appetite for batteries. I believe the factory alternator undercharges the battery at low rpm's which causes this issue. The best charger I've used is the CTEK; it has been able to bring batteries back from the dead on more than one occasion.
#43
surfing the internet(so this must be true) it appears that there is no reason not to store a battery on concrete. in the old days battery cases were made out of wood and pourous plastic that would absorb moisture from the cement. new batteries are made out of polyproplene cases that do not allow moisture to seep. storing a battery without movement or charge will kill a battery over time whether on cement or not. on cement in winter it may be colder on the bottom of the battery as a result of storing on cement but batteries shouldn't be allowed to freeze anyway. this is an interesting (to me) thing as many mechanics and car guys believe this myth to be true about not storing batteries on cement. what do you think Phil?
#44
#45
i do leave the battery in the basement but have it sit on a chair and charge it once every few weeks. the battery is fully charged now. thanks for all the feedback and should be taking it out in a day or so. way too nice out to just leave the car sit around.
Thanks!
Thanks!
