Extended Warranties?
Captain Obvious
Super User
Super User
Hello ! It was around 975.00. As the others in the thread have indicated, there are more expensive and comprehensive ones out there. Its all about mitigating your risk and deciding what that means to your pocket book. You can spend 5K and never use it, or 1K and get 3 times its value. Its a bit of a crap shoot, but so is buying a used car .
5th Gear
Hi Guys,
First post for me.
I'm in the process of buying a 2002 911 Targa, US Car, and bringing it up here. Among the many, things that I have been researching is an extended warranty. I just got a quote from Ensurall for a 3yr/65K basic powertrain warranty for 2899.00. The guy I talked to said that they only offer thier basic coverage warranty on Cars over 6 years old and that has a per claim limit of $2500.00. Not much help if "you know what" happens.
They will cover the IMS bearing, up to that same limit, but how do you prove that it's going until it's gone? If I could get them to cover it now, as I'm buying the car somehow, then it would be worth it. The cost of that repair plus the clutch would be around $3000 anyway(quote from Mantis Racing in Oakville) Then I would still have the warranty for other powertrain parts.
I'm not sure what to do? Thoughts?
First post for me.
To revive a dead thread - sorry - but was chatting with a buddy about after market warranties...
I had Lubrico on my '07 Volvo V70R ($2100) - it DID pay for itself in the end as I had an angle gear failure (big $$) and a couple of other minor issues. BUT, you can only use approved Lubrico mechanic, they have to try to find used parts first and things literally have to fail / fall off before replacing under warranty - I had numerous bushings that were cracked and not doing much, but because they didn't disintegrate, or cause catastrophic, were not covered (I replaced them all on my own dime). Most things that wear out or wires that wear out and fail are not covered either.
If it helps you sleep at night a little better...
Actually the "ONLY" place I found who does a great g'tee is "Long and Macquade" (music shop)
I had an amplified speaker, which was hardly used, and it blew, 3 weeks before the standard w'tee.
They sent it off to repair and gave me a loaner, for 3 months! while it was in the shop, no charge, no quibble, no arguments.
The worst con I had was for a big box store in the UK
bought a shed load of home articles, washing machine, fridges, hifi (I was moving to a new home)
They had a extended w'tee for the washer, for £200 for 3 years (extended after the 1st) IF I didnt use the w'tee on the 4th year I'd get my 200 pounds back !
So once I nearly needed to use it, but managed to live/then fix the issue (small leak) on the 4th year
guess what..........the company went bust !
