3.2 Case/Engine to Rebuild
Hi,
As title states, I am looking for a 3.0 or 3.2 case or engine that needs rebuilding. I am in Oakville Ont., between Toronto and Hamilton.
James
James
I have had very good treatment from whaletail. He does a leak-down test, and visual of engine before he purchases them. Porsche-Apart does not do a leak-down.
However, I am after a 3.2 block with a crank. I would have thought there would be a one collecting dust in someones garage. Perhaps wishful thinking.
Brad, you could do a 3.4, pretty much a bolt on mod using 98 mm pistons/cylinders. Uses the stock motronic.
Or just Euro pistons and cylinders, no additional modifications needed, should be good for 230 hp.
Brad - you SHOULD grab my 3.6 - it is remarkably strong - needs a reseal - but is otherwise in great shape and still in the car - so can be "auditioned" anytime.
Let me know!
RK
Let me know!
RK
