View Poll Results: What fuel do you use?
Shell V-power 91
67
89.33%
Sunoco Ultra 94
8
10.67%
Voters: 75. You may not vote on this poll
What do you use? 91octane V-Power or Sunoco Ultra 94
Old 07-17-2010, 11:33 AM
  #31
Dale Gribble
Pocket Sand
Dale Gribble's Avatar
Originally Posted by Cosmo Kramer
Ultra 94 is the only thing that will keep my 7 psi S/C 928 from detonating at high RPM's. I even hooked up the octane loop on the computer to retard the timing 3 deg and it still pinged on 91. Ultra 94, no problem stock timing. It is a little sooty out the pipe though.
If i had a boosted car, or a car converted to an SC/Turbo, or even an N/A with High-Comp Pistons I would favor the higher octane for the reasons you just mentioned. Hell, I'd tune for 114 if it wasn't 5$ a liter.
N/A guys in stock water-pumpers can do fine with 91 V-Power tho. My 996 C2 runs better on 91, gets slightly better mileage (both computer and hand calculated...because i'm a nerd) and the fuel lasts longer sitting around between uses. The only shameful part of it is using fuel designed for Ferrari in a Porsche
My 2 cents (.3 cents US).
Old 07-17-2010, 11:39 AM
  #32
raspberryroadster
raspberryroadster's Avatar
Originally Posted by Ronan
I have never thought of using an octane additive. Does anyone do this?..any negatives?
with my last car (04 cobra, blown with about 18p.s.i.-dyno'd at almost 600rwHP) i used lucas octane enhancer if i had the view i would frequently go WOT. or if i was traveling (most places max out at 91 or 92). if you search out the net there are some comparisons re effectiveness of various boost juices. lucas tho' pricey apparently 1 of the best & available here at Cdn.Tire.
in the p-car & last car use chevron 94, pump clearly notes it contains no ethanol, and its the only gas that comes out of its own individual pump.
never encountered any pre-ignition/knocking issues with it in any mode.
Old 07-17-2010, 01:30 PM
  #33
Matt Lane
Matt Lane's Avatar
Originally Posted by FFaust
Matt, I agree with your comments but how would you explain the survey results? Pack mentality?
>>> More than likely, yes. In fairness, Shell does a lot of (good) advertising, and there is no question that ethanol is a dirty, political, short-sighted screw job foisted on the public. It's harmful to old injection systems (CIS and others), provides lower fuel economy since it inherently has less power, and mixes nicely with the condensation in your tank over time. Lot's of negatives for ethanol for sure. The question is what's worse? Low probability of injection issues on modern cars, or detonation? I worry more about the latter, especially under heavy load. If I was just tooling around for a leisurely drive, I wouldn't worry a bit.
As stated above, I have switched to V-Power due to the "concern" over ethanol but I must admit that I am uncomfortable with its low octane rating.
You seem to know what you are talking about. Would you care to elaborate on your comments? It really is a bit obscure at the moment. Should ethanol really be a concern or is octane the only parameter worth tracking?
>>> I'm definitely not an expert, but have done a lot of reading over the years, paying particular attention to mechanics that maintain and rebuild air-cooled engines. The same would apply to engines with forced induction - they all run hot.
In cars that run hot (air cooled, severe loads, track, high ambient temps), I believe the benefits of higher octane outweigh the downside. That said, I don't run the tank low to keep condensation down, and I switch to Shell 91 as soon as the weather cools and track season is over. Definity for long-term winter storage.
I have sent an e-mail to Sunoco to ask about this and will report if they do.
Best,
Matt
Old 07-17-2010, 05:27 PM
  #34
FFaust
FFaust's Avatar
Old 07-17-2010, 07:14 PM
  #35
pongobaz
pongobaz's Avatar
Yeah, you guys are lucky in Vancouver...I was told the same when I was there last week.
Old 07-17-2010, 07:44 PM
  #36
raspberryroadster
copy that.....as we finalize plans to move back to tokyo in january will definitely miss - 30 minutes out of downtown early sunday a.m. nice winter morning, topdown/heater blasting, driving into the clouds up mt seymour.
Old 07-17-2010, 08:07 PM
  #37
pongobaz
pongobaz's Avatar
Yup, my favorite city in Canada, I feel sad every time I leave it and I'm there 6+ times a year. Sat on the pub-side deck of Bridges on Wednesday evening with a couple of friends taking in the scenery...glorious!
Old 07-17-2010, 08:30 PM
  #38
9 lives
9 lives's Avatar
Originally Posted by Christien
fwiw, I've never noticed any difference in performance between Shell 91, Sunoco 94, Esso 91 or even regular cheap stuff, the few times that's all that's been available. I figure even the cheapest stuff available today is better than the best stuff they had in 1972, so it's not surprising I don't notice any difference. I use the Shell 91 in the hope that it'll be better for the engine over the long run.
I would have thought that yours would have required a lead additive, if anything. Not trying to be a smartass, just kinda assumed that it would have just been a natural requirement of the car from day one.
Old 07-17-2010, 10:42 PM
  #39
IXLR8
IXLR8's Avatar
Originally Posted by 89VWdieselGolf
What do you use? Any reason for it?
Shell V-Power because that station is nearby and the previous owner mentioned something about using it.
As far as the octane value, I think we're getting ripped. I buy Shell V-Power 100 in Europe which is about a 95 in our rating system.
Old 07-17-2010, 11:58 PM
  #40
GTA_G20
GTA_G20's Avatar
shell, because its pure!
Old 07-18-2010, 12:10 AM
  #41
Christien
Christien's Avatar
I've wondered the same thing, but I've never known anyone with a vintage 911 (or any other vintage car, for that matter) that uses leaded fuel, not that you could find it anywhere around here. We all just use regular gas.
Old 07-19-2010, 10:34 AM
  #42
ronnie993tt
ronnie993tt's Avatar
Question
I get 10% to 15% higher mileage in both cars with V Power. The 993tt Porsche manual says 91 octane is OK and Excellence said in their tech section (last month I think) that ethanol is not good for any Porsche engine.
I'm thinkin' Ronan's additive idea might be worth the expense. Anyone done any experimenting?
Old 07-19-2010, 11:25 AM
  #43
Torontoworker
Torontoworker's Avatar
I'll let you in on a little secret thanks to the next door guy who works as an engineer for a major fuel company who run the last cracking plant in in Eastern Canada (Sarnia) after Montreal is shut down:
There is only ONE base fuel for sale in Ontario. The tanker truck drivers mix the 'packages' into the tankers when they fill up. Each company has their 'secret' blend that is dumped in for them. He laughed at me when I was like, 'But, but, but...' "The marketing works huh", was his reply?
Most of the cost factor in fuel (other then crude) is not reseach costs - but marketing overhead. We should all be pizzed off that we have the worst fuel in the G20 before we go on about RON ratings. Europe wouldn't run construction vehicles on that crap we call diesel. We still have trace sulfer in our fuel that is a throw back to the old cracking process which is one of the reasons the Monteal facility is closing after near on 100 years of operation in the same location. We are held hostage to the US market as most of our fuel heads south and is made for low US spec's. Until they change expect the same crap as usual. Diesel *may* be changed by 2014 to match euro standards but don't hold your breath.
Old 07-19-2010, 11:27 AM
  #44
Ronan
Ronan's Avatar
Thats why you cant get the high performance diesels you get in Europe. Our fuel is too poor in quality , Very high sulfur in diesel here.
Old 07-19-2010, 11:48 AM
  #45
petee_c
petee_c's Avatar
I use the 91 at Cdn Tire almost exclusively in our vehicles that require Premium for the past 5 yrs. Mostly due to the 'Gas Advantage Card' which allows us to save 8c (was 10c) per liter.
We probably put close to 60,000km on our vehicles each year, plus boats, watercraft and sleds. The savings is fairly significant.
TOworker, interesting comment on the marketting.. I would say about the same thing with most domestic beers. I may drive a Porsche, but I drink Lakeport while working in the garage or in the basement. I get ribbed about it to no end.
I also tease my bro-in-laws about marketting and their MBA's.... They work for the big 3 mobility companies, and I always kid them that the pimplefaced teenager at the Wireless Wave kiosk probably sold more cell phones than they did.....
P
Quick Reply: What do you use? 91octane V-Power or Sunoco Ultra 94
