Powder coating brake calipers, where in GTA?
Bergamasco:
I guess I should also let you know ... dealer at woodbridge charges $75 for each spring kit (1 required per caliper). Quick price check at Suncoast shows $20 for set of fronts.
Call Colourfast in concord - they specialize in powder coating and that's all they do.
905-660-3454 ask for Joseph. Tell him the guy who just got his exhuast tips done in black sent you.
I'm going with high temp enamel out of a rattle can. A lot of my stuff (steel) gets powdercoated and it's really nothing special. Usually a polyester paint that gets baked at 400 deg C. The powder gets attracted to the negatively charged part and when heated flows( sort of) into the nooks and crannies of the part. With calipers they really should be disassembled with the pots masked. Min charge $ 250. IMO not worth it. Rims on the other hand, hmmmnn.
I am in the process of doing mine (2 fronts done, 2 backs this weekend). The Dupliclour kit has worked very well so far and you dont need to take them off etc etc (and its brushed on, not sprayed)
At least this didnt devolve into name calling. When I was searching some previous threads on how to do this, several times these discussions turned into almost fist fights ("I will meet you anytime anywhere!!") about poseurs, fake "big reds" etc. Lifes too short. I like them on my all black cab but to each his own.
