Daytime running lights - question
Team Owner
I think Phill enabled his through the comouter .. I can't imagine the new Boxster being any different .... but I concur with TurboDAn .. pics please ...:-)
While on the topic of DRLs, mine is a Canadian car & has the Xenons. The DRL used to work but now they do not come on when the car is started. The lights do come on when the headlight switch is turned on. Is this a simple correction or should I just leave it as it is?
my first guess would be that it is the DLR relay, the relays are located under the dash just above the fuse panel. It is a big double relay in position 6 & 7 i think ...
