oil for 911
Team Owner
oil for 911
Hi Guys
The usual discussion is on about oil and how crap the castrol GTX is on the 911 forum. Many of the oils discussed are just not avalable here. I have stated "crap" now in my car and am due for a change, just wondering what you guys are using. PS I am not and do not intend to run synthetic, don't want to start another debate so if the Dino' guys can chime in that would be great.
Thanks guys
Thanks guys
My mechanic uses Quaker State 20W-50 dino oil in 911 engines unless the owner supplies something else (I use Mobil-1 15-50). FWIW, he works almost exclusively on pre-1990 911's (and 356's) and is known as the 911 engine builder to go to in the area.
Oh, and on a related note, it appears that Mobil-1 had dropped the 15-50 for Canada, replacing it with a 5W-50. http://www.mobil.com/Canada-English/...es/Mobil_1.asp no longer lists the 15-50, and my local CdnTire only has the 5W-50.
Ice ....I bought my oil locally here from the Tractor Supply Company, otherwise known as TSC....bought a case of twelve....somewhere around 60$ I think. Could be less???........Bill
I too, am interested in this Castrol GTX bashing. I always thought the consensus was positive if you've always run dino. And if you're changing every 3K to 4K does it really make a huge difference as long as it is a premium oil & the right weight?
Ian
Ian
Team Owner
Hi Guys
Not sure if I can send a link from here but I iwll try .. nope can't figure it out ..
go to the 911 forum and check out the thread " weird gas mileage change "
all stories are anecdotal but this is worth reading.
Hmmm. The more you read, the more confused you get when it comes to oil. ice is right, Pete Z & Steve from Rennsport etc give a thumbs down to Castrol GTX. Many guys use it though. And The Oil Bible rating is a miserable 625 in 20w50. Hmmm.
Everybody does admit that with 3K oil changes, any quality oil (GTX included) will do.
Ian
Ian
I've run Castrol on all of my cars for many years without a single engine problem.
Switched to Quaker for a short time but found my Toyota burnt up more Quaker than Castrol so I switched back.
Can't go wrong with the price.
911 and BMW get Mobil 1 though.
