OT - House Electrical Work
Old 03-26-2021 | 06:02 PM
Adamant1971's Avatar
Adamant1971
Originally Posted by DDzPorsche
Make sure your car is in the garage with door closed to avoid the 'Porsche tax'
Lol I was going say that. Even with old 928 I get hit with the p-tax.
Old 03-26-2021 | 06:45 PM
Lemarp's Avatar
Lemarp
The Porsche tax I got hit with was nuts.
Contractor showed up early and quoted (i'm not even joking) $110K for a detached single car garage.
Old 03-26-2021 | 07:15 PM
Tj40's Avatar
Tj40
Not surprised - I was getting some quotes done to enclose a covered porch at the back of my house and I had one contractor tell me 'we're $100K' before he even looked at the job!!
Old 03-26-2021 | 09:34 PM
JimV8's Avatar
JimV8
Team Owner
Originally Posted by Henley1
Yes if it’s your house you can pull the Esa permits and do it yourself. It’s like 200 or so for permit. I think that’s the min, then x amount extra for each “device” (plug/light/switch). Sounds pretty straight forward, check O’Neil electric supply or independent.
You must do all of the work yourself and the ESA permit is twice as much as charged to a licensed electrician. $500 as I recall, and it’s because the inspector has to really do the inspection. Electricians have a deal going where their work is pre approved due to some kind of competency demonstration. I like doing electrical and it helps that I was trained by a master electrician many moons ago, he taught me to be meticulous in every aspect of the work. I still remember a lesson he taught me when he said, ‘remember this, one day you may be called to a coroners inquest to explain why you did what you did.
Old 03-27-2021 | 01:24 AM
Gregster's Avatar
Gregster
The covid tax is a real thing. We are having a new HVAC system installed and while prices were about what I expected it's still 25% more and basically was told "you need to sign by the end of the week for installation before June" I brushed that off as a sales tactic.. sadly it wasn't.. also had to get my electrician friend in to run a new wire etc outside. He said it's insane how busy everyone is, shortage of materials as well has left some jobs at a standstill.
Old 03-27-2021 | 01:27 AM
petee_c's Avatar
petee_c
I've done a bunch of electrical in my own home.... just don't cut too many corners. And have it inspected either by ESA or an electrician....
Old 03-27-2021 | 03:22 AM
#1SomeGuy's Avatar
#1SomeGuy
There's no either...it must be inspected by the ESA to be legal.
Old 03-28-2021 | 02:37 AM
petee_c's Avatar
petee_c
Legal yes, safe - no...
You think everyone perusing the electrical aisles at HD is getting an inspection?
Old 03-28-2021 | 01:00 PM
#1SomeGuy's Avatar
#1SomeGuy
You're allowed to change switches/plugs/fixtures without a permit, but anyway, the point I was making is that an electrician cannot on their own approve your work from a legal sense and hence it's not an "or" situation, you must get an ESA inspection even if an electrician has looked at it.
Old 03-29-2021 | 09:41 PM
Gregster's Avatar
Gregster
My electrician was by and was saying how there is a shortage on breakers going on
Old 03-29-2021 | 11:45 PM
pfitzsim's Avatar
pfitzsim
I had heard the same, however I only need a handful (like 6) and my nearest HD store has close to 100 in stock with 2 other stores in a 8k radius. I only need 15A so perhaps the shortage is on the big boy stuff.
Old 03-30-2021 | 05:14 PM
steam_mill's Avatar
steam_mill
I just added additional outlets in my garage for car lift and Porsche charger. Garage had 2 outlets. Now has 9 to ensure I never need extension cords. Safe? yes. Legal? No
Old 03-30-2021 | 07:45 PM
pfitzsim's Avatar
pfitzsim
Assuming that another 30 outlets aren't on the same circuit as the initial 2 of course.
Old 03-30-2021 | 10:21 PM
steam_mill's Avatar
steam_mill
Dedicated circuit to the garage. Garage lighting on a separate circuit.
Basement is fully finished and panel is 50 feet away. I would have run 2 more circuits otherwise. House has 200 amp service and all electrical is less than 2 years old. Has 200 amp service due the hot tub and laundry room is equipped with dual washers and dryers. and it is only a 2 bedroom house lol.
Guy that renoed the house went overkill on the house. Unfortunately, not a car guy so besides a beautiful garage door, didn't do anything special to the garage except a new pad. I'm fixing up the garage prior to move in. Lift gets installed in mid April.
Old 03-30-2021 | 11:06 PM
Gregster's Avatar
Gregster
I have the issue in the basement and garage. Not enough outlets and the ones that are there... In the worst spots ever
Quick Reply: OT - House Electrical Work
