Insurance for Ferrari
Originally Posted by Bud Fox
Wonderful cars. $30k engine out services.....not so much
LastMezger (07-23-2020)
Captain Obvious
Super User
Super User
If you want a car that will drain you wallet then get a Ferrari. As good as they are, they are not reliable or easy to work on.
2nd gear issue is actually rather common on abused examples. Make sure you get on the good side of the local Ferrari mechanic. Our local guy is great and we help eachother out with car stuff.
You can do about 85% of what you need with the engine in the car. Belts can be replaced through the acess panel , you will need to remove the seats. I drove a 360 all of last summer and it was a blast. Yes it's dated and all the interior switch gear gets sticky/ worn but it makes all the correct sounds.
We have two 360s one is my business partner with about 40k and the one I got had 90k so it got driven. He actually prefers his R8 V10 Stick. A stamped service history or binder full of invoices will do more for value. Ferraris need to be driven! And driven hard. Last I checked Ferrari Quebec had a 360 stick for around 120k.
Looks like thread got derailed a bit. But to answer OP's question.
With TD. Here's what I pay
991.2 Targa GTS: $180
Ferrari 458: $225/ month. No mileage / commute restriction
I'm unsure. Ferraris arent horrible for reliability and for most parts they aren't bad, service stuff anyways. The older models are easy enough to DIY for most. It reminds me of the people who buy a used Bentley and except VW Golf running costs
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Captain Obvious
Super User
Super User
When you lift up and older Ferrari, it looks like a kit car put together by someone in their garage.
Well that and it'll be $15K to fix;-)
I had a mint 2001 360 manual. What a great car. Regret selling it. It also would grind 2nd gear on high-RPM shifts. I had the whole service history and after reading it more carefully there was a service at Ferrari of Quebec that noted "2nd gear synchro!" Actually had the exclamation mark LOL...
