Ceramic is a spray/wipe on application but you are supposed to be paying for paint correction and beautification before the ceramic application.
It's not required to do paint correction before applying a ceramic coating, but frankly, I would always opt for it. Ceramic coatings do NOT fill in scratches and swirl marks. Paint protection film does help to obscure minor swirl marks, but you can still see them in the right light conditions.
Think of the coating (and paint protection film) as something that is going to lock-in the current appearance of your car. If you aren't the type to worry about scuffs and swirl marks, then paint correction won't seem valuable to you.
But for me, I want the paint to look as good as possible before I permanently seal in that appearance. So paint correction is an important first step on MY own personal vehicles...
pricing on all this paint protection makes absolutely no sense. I am in the same boat and have been contacting several installers. ppf 5-6K and ceramic anywhere from 2-2500 for car with wheels/calipers. I don't mind paying 1200 or so for ceramic but 2500?? it's a spray on application!!
Porsche Oakville quoted nearly 10K for both applications, ridiculous!!
Ceramic on wheels and brakes has to be a waste of dough IMO. How much easier can wheels be to clean? If they are left for a month or so maybe they are tough to clean up but if you clean them once a week I can't see coating making it any easier. Shine may be better. Ceramic coated cars do look amazing.
I can't see Ceramic over PPF....you're making the film "POP" not the paint. Just my opinion.
IMO, ceramic coating is the best form of surface protection for wheels. They experience intense amounts of heat, brake dust, rotor dust, oil and grease, and road debris. Ceramic coatings provide the best protection and longevity to keep these contaminants from permanently etching or damaging the wheels painted finish.
Of course, keeping the wheels clean at all times is also an excellent defense against damage to the wheel finish. But many people simply can't clean their wheels/car as immediately as they would like to.
Originally Posted by 911boy
Shine may be better. Ceramic coated cars do look amazing. I can't see Ceramic over PPF....you're making the film "POP" not the paint. Just my opinion.
Modern ceramic coatings do look great - and play the same role on PPF as they do on paint+clear coat.
Create a durable layer to protect the finish from chemical damage, etching, staining
Provide a hydrophobic layer that makes water and contaminants more likely to run off, and to make cleaning easier
To enhance the gloss of the clear coat
Whether ceramic coatings are applied to the clear coat directly, or the PPF's clear-coat, you're getting the visual and protective benefit of the ceramic coating.
I can't see ceramic coating protecting the paint against stone chips to the same level or better than PPF. Don't know much about ceramic coating.
No, you're right Alex. Ceramic coatings are not designed to replace paint protection film. PPF still provides the maximum protection available for stone chips and small impacts.
Coatings are intended to provide a long lasting layer that provides chemical resistance to protect the finish from staining, etching, and prevents contaminants from bonding/embedding (eg tree sap, metallic deposits, etc). But because of the hardness of the cured compound, it also provides some enhanced scratch resistance. While there are demonstrations that show how a coated surface can resist scratching from glancing blows, the more common benefit IMO is in resisting 'self inflicted' scratching during the washing and drying process. That's typically how most swirl marks and hazing is caused.
Many ceramic coatings have a hardness rating of 9H - meaning, the coated paint panel can resist scratching from the hardest graphite (9H) in standardized "pencil" testing. I've read that clear coats typically range in hardness from 2H to 4H without a ceramic coating.
My brother in law is a detailer and we have discussed this topic in depth. Ceramic has its benefits mentioned but also has serious drawbacks. If you do get a light scratch it’s difficult to take it out because if you buff one panel it will no longer have the coating. Then you can’t recoat that panel and have it look right, the whole car would have to get compounded down and redone. He recommends a light paint correction with a high quality synthetic wax every 6 months.
Everything you are saying about ceramic coatings is 100% spot on, I'd just be careful in considering it if you are someone that doesn't wash their car very often. A ceramic coating is sometimes mistaken for an excuse to never wash a car again, which is very far from the truth. The paint correction will bring your cars paint to life and it will look fantastic. The coating will keep it like that for a long time as long as it is maintained. However, if you get the coating put on and never wash your car again, I'd be impressed if it made it a year before the coating wore off. Just something to consider! Hate to see you spend your money and then be disappointing a short time later.
OK...confused.
Why can't I recoat a panel and not have it look right? Does it change the colour?
I've also been of the wash, clay, polish and wax type.
exactly right. it definitely doesn't. a ceramic coating will protect against a lot of contaminants that can effect your paint. PPF is the best thing on the market to protect against any chips.
The ceramic coating wears down over time. So say its supposed to last 5 years and 2 years in you have to buff out a scratch. The one panel will look shiner if it gets paint corrected and recoated in comparison to the rest of the car.
exactly the reason why some recommend to NOT do wheels or other intricate parts
That would be true regardless of the type of coating/sealant you've used.
One of the key benefits of ceramic coatings is that it preserves a just-polished finish for several years by creating a durable chemical and scuff-resistant layer on the paint surface. If you got a scratch after 2 years that you wanted to polish out, you can do that and the remaining panels should still be in really good shape IF you've maintained the car appropriately (ie regular washes using good products and processes). But strictly speaking, it's not true to say that a 2-3yr old panel will definitely look worse or "less shiny" than a more recently polished + coated panel.
It would be a judgement call about whether the entire car has degraded to a point that a newly polished panel would stand out. And if that is the case - it suggests you're due for another polishing anyway.
