2001 996 battery current draw
Old 08-14-2018, 10:47 AM
911 Rod
911 Rod's Avatar
Originally Posted by Granger968
Why not get this one rebuilt?
Old 08-14-2018, 10:53 AM
Granger968
Granger968's Avatar
Originally Posted by petee_c
Granger,
How did you measure amp draw? With a multi meter or one of those clamps that goes around the battery cable...
Just wondering if I have ever have to diagnose a parasitic draw...
Fluke multimeter, and follow Iceman's directions, start with highest setting. 10A should be plenty..
Old 08-14-2018, 04:35 PM
Adamant1971
Adamant1971's Avatar
+9
Oakville Starter & Alternator has rebuilt several p-car alternators for me. Highly recommended.
http://www.oakvillestarteralternatorlimited.ca/
Old 08-14-2018, 07:03 PM
Granger968
Granger968's Avatar
Originally Posted by Adamant1971
+9
Curious, how much do they charge you? How much for new (for the model you were looking at) ?
Old 08-15-2018, 09:30 AM
petee_c
petee_c's Avatar
Originally Posted by theiceman
standard multimeter is usually fine for this. JP's was unusually high but even at that, most meters will handle around 10amps. Just remember to start at the highest setting if it is not an autoranging meter and adjust the meter down for better resolution. If not you can blow the fuse in the meter.
thx.
kinda like this? (I don't know if the polarity matters, but I think this pic might be backwards....)
Old 08-15-2018, 11:51 AM
Adamant1971
About $200 for a full rebuild on a 928 S4 Bosch unit. From Porsche over 1k for a rebuilt unit with $85 core charge.
The rebuilds come back fully painted and looking like new. The rebuilt one on my 87 is still running a solid 14v after about 20k km's.
Old 08-15-2018, 11:54 AM
bcrdukes
bcrdukes's Avatar
$200 for a rebuilt alternator is not a bad price at all.
For those who are handy, you can buy an alternator rebuild kit and do it yourself and have a lot of money leftover.
Old 08-15-2018, 12:41 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,027 Likes on 731 Posts
thx.
yup
the key is disconnecting the battery and putting the meter in between so the current flows through the meter ( in series as you mention ) . This Is why you start on the highest setting, too much current and you can fry your meter or at least blow the fuse.
If you had a parasitic drain you would connect as you showed and look at the total current draw from the battery. ( mine is 15ma ) . if it was high ( say 200-300 ) you would start popping fuses to see what circuit is causing the draw (exactly as JP did ) . If it suddenly drops you now know what circuit is causing it .
In JPs case no subcircuit was causing it . There is a direct unfused high current link from the alternator right to the battery to charge it . The alternator has a diode bridge in it to convert ac voltage generated from the alternator to DC voltage required by the car . Diodes allow current to flow only one way . When one goes bad it allows current to flow the other way from the battery and discharges it.
This is what makes me think the regulator wont fix it . I think he has a diode pack issue.
Old 08-15-2018, 12:51 PM
Adamant1971
Before and after rebuild. I would do it myself but when they go in looking like a bag of crap and come back like this it's an easy choice. This is the 89 Euro that sat in a wet garage for 10 years.
Old 08-15-2018, 01:00 PM
theiceman
Team Owner
theiceman's Avatar
usually a rebuild covers bushings, lathing the commutator and a new regulator . I would be surprised if it covers the diode pack . most times they are spot welded in and its a bit of work to replace , even if you can get one.
Old 08-15-2018, 01:02 PM
911 Rod
911 Rod's Avatar
I agree letting the pros do the rebuild. In my eyes there is nothing prettier than a freshly rebuilt alternator or starter.
The beauty of it is there are lots of places to get it done.
Old 08-15-2018, 09:53 PM
Granger968
Granger968's Avatar
Got a rebuild yesterday. Ordered at 9am, delivered at 3pm. Won't be able to install it until the weekend though...
Quick Reply: 2001 996 battery current draw
