Renovating the Garage... Here I go!
Building code calls for 5/8 inch fire rated drywall and fully sealed joints to prevent gas fumes from entering the house. I think you will need to put the paneling on top of the drywall...
https://www.constructioncanada.net/c...th-spray-foam/
Couple questions:
I assume that that those ceiling cross beams you cut and relocated have no effect on structural integrity?
Did you ever consider a roll top door because even though you raised the ceiling, the door will only go up as far as the rails are long and it looks like only about 2.5'.
Vapor barrier will be applied too before your wood?
Will the wood be finished? Shelac, varathane whatever? Like floors, it'll expand and shrink with temp and humidity.
Is there anything in the fire code for wood walls in a garage environment as obviously, wood is not fire rated. Just curious.
Hi Jason, I believe that garages fall under a different code. I know that we had to use 5/8 drywall in the garage to meet fire code (1/2 could be used everywhere else) and that all seams must be sealed to prevent gas fumes from entering the home. I’m sure another member with more knowledge than me will chime in. Maybe the code has changed since 2008? Project looks great so far!
Couple questions:
to be honest, I’ve thought about adding heat in the form of a small gas force flow heater but most likely don’t see myself requiring heat in the garage for the winter months. If I had a true 3 car garage I would defiantly consider it, this way I could dedicate one bay to a small shop like area. But it may make sense to install a vapor barrier since it’s cheap and easy and can act as a air barrier as well in case the spray foam is not sufficient. I’m going to confirm at work today, just want to make sure that if I put up a vapor barrier, it’s not going to trap condensation where the garage wall meets the interior walls since I assume there is a vapor barrier on the interior wall behind the drywall.
Whatever roofing you are now closing in and insulating. You will need to vent the roof, as it was never designed as a closed chamber.
Here is how I think of insulation. Once the heat is through the insulation, you want it gone. It is of no use to you. While you may not have heat source, like a gas furnace, or electric base board.
Even a hot car engine will warm the garage now that it is insulated.
As above. Check fire code. For my area, 5/8th is fire code for any wall attached to living space. And "X" inches away from the lot line.
I also hate dry wall. It's heavy, brittle, and holds a lot of moisture. Moisture is difficult to heat up. I used plywood for all my garage walls.
It takes a beating. I can hang anything I want anywhere. Easy to heat up, as it is low moisture. And best of all, easy to remove if I need to make a change.
This is not my garage, but one of my favorites. Heated granite floor, field stone fire place, beer taps, and Karaoke machine. If I was single and rich? This is what I would build.
But I'm married, and tired.
If I had that garage in your picture I wouldn't need a living room lol!
@911 Rod, I have been a lurker there for years haha, but I agree expert advise is defiantly there, I just find most of what is posted is US based with their codes etc.. Seems like in the US fire separation is required for most states.
Suggestion: Add a urinal. Forgot Rennlist username but someone here had one in their awesome man cave/garage. Made perfect sense -- gotta whiz but don't want your friends to inside to wake up the missus and leave spray all over the floor.
Waterless Urinal.... 987981 and I are just the idea guys.
https://www.amazon.ca/Waterless-2104...terless+urinal
Know any good framing contractors?
