Montreal garage Gundo hack
Call us 514-505-4445 Momentum Motorsport. I did two of this this week so far... One on 997 C2 and 996 C4S
Its a bit odd depending on year. The PSE mod or bent J pipe on older mufflers 2001 ish and older won't add that much sound compared to 2002+, Yeah its a bit more aggressive but don't expect it to shake the ground. The "Fister" style will be the loudest out of all the cheap exhaust mods. The only bummer is that doing the job properly requires removing the mufflers off the car. The J pipe can be welded in place but the Fister style mod can't, there is no room to weld. So you will likely need a few new clamps, bolts and hardware.
