Panamera GTS rear spoiler not working
Hello,
I have an issue in a Panamera GTS 2013. the spoiler does not retract and is kept up. I scanned the vehicle on PIWIS and a fault code 81020E "Spoiler Motor Speed Sensor Plus Faulty". I have checked the wiring but did not find any problem. I suspect the spoiler controller relay, but do not have an idea about its location. Any advice?
Hello,
@ekranoplan I ended up pulling the whole spoiler assembly out (open trunk, remove plastic panels, mounting hardware is there) and found the whole mechanism totally rusted together from the drain plug getting clogged by leaves and then water sitting on it. Wing assembly from Porsche was horrifically expensive, but such is the bed we've laid for ourselves. If you're able to find one on a wrecked car from car-part.com or something that may be a good route.
- Grant
- Grant
ekranoplan (09-21-2023)
