PORSCHE CAYENNE S 2012 Air Suspension
Hi All,
It seems my air suspension started leaking after noise at the air compressor and 85,000km. The car lowers (only the front part) at random times without changing the setting.
There is also a note in the computer that higher position for the suspension failed.
Any advice on what is wrong and where I can repair the air suspension, buy a compressor or replace with Bilstein air suspension?
Thank you all in advance.
Hi All,
If only one side, that individual shock or lines have some leak? If both, could be valve block near the compressor is faulty.
Had the exact same problem on my '12 CT. Turned out to be an air leak in one of the front struts. I also was hearing a noise from the air compressor, but nothing was wrong with it once the leak has been fixed. The air compressor in this generation is more reliable than the older one.
On mine now of the rears has starting leaking, but it's not as bad and the system is working fine for now. These are one of the weakest parts on the 958s.
rnlst_log (07-12-2021)
Me too in Doha.
CTT-QTR (07-14-2021)
Nice to meet a fellow member from Doha!
Although one was faulty and I didn't want (and the dealer) to do guess work of where the air was leaking from. So, I opted to change both whole struts at the same time as it's always good to do things in pair for suspension related components.
I blame my driving style in those early years of ownership and you know we had some nice streets back then. No issues whatsoever since I replaced them 6 years ago. Now the rears started to go bad.
Make sure the valve block is not the culprit before the struts.
I have piwis 3 setup ready if you ever need it.
Cheers.
compared to other air suspensions, its very good, much more reliable than other car makers, but def has its faults. If you want to save a lot of money, they sell these struts on aliexpress for like $250 each which is a MASSIVE savings. They have good ratings and a lot of sales as well. Ofcourse you cant trust the ratings but the sales mean that they probably work pretty well if a lot of people are buying them.
I know this is not the same, but i recently replaced my rear powered liftgate struts with ones from china/aliexpress, and not only do they look EXACTLY like the porsche ones, they operate the same exact way as well. Same speed of liftgate opening, can adjust how high it opens, and every single thing the porsche ones did these ones do exactly the same way at 1/3rd the price. The real test will be seeing how long they last. Time will tell, but the parts im seeing come out of china now are pretty impressive. Def not the chinese quality of the past/early 2000's.
aliexpress listing selling all 4 struts seperately w/ 2 year warranty if your interested - https://www.aliexpress.us/item/22518...d=qBgNmAu7PVM0
