performance friction 08 or Pagid RS29 brake pads
Basic Sponsor
RS29 must be bedded in as specified by Pagid. PFC 08 requires no special bedding. Both will make road noise ...like a shreak when you apply brakes.
PFC 08 will definitely outlast Pagid and has more initial bite. Some of the faster cars GT4s and GT3s have told me that Pagid will no longer stop the car when you get down to less than 1/2 the pad.
PFC is pretty much good to the backing plate.
PFC runs hot on the rotors where RS29 runs cooler and is friendlier to the rotors.
IF you are doing mostly track stuff you should consider Ferodo DS1.11.....very friendly to the rotors,
must be bedded in and will schreech but the modulation and release is to die for. Of all that have gone from PFC or Pagid to Ferodo I have only had 2 guys go back......all the rest rave about the performance.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
I ran PFC 06, 08, and 11 in a Cayman S. Didn't like the 11 and when I needed pads for my GT4, 11 was the only choice. Tried the Ferodo DS1.11 and am very happy with it. They were very noisy on the street but this has calmed down and I'm leaving them in all the time. Recently one my friends who is running a GT4 with Pagids remarked that my rotor wear is much less than his.
the result is no noise, on or off the street or track.
icepenguin66 (08-19-2023)
I use the 08s on a dual purpose car. They're quiet, long lasting, have good performance on the track, and cold bite is adequate. Only downsides are more dust than a street pad, the occasional squeal (usually only when I have been doing too much street driving) and a softer pedal on the track than I'd like. Not sure I can blame the pad for the last item though.
I switched from the RS29's to the 08's and couldn't be happier. The Pagids were bad in the street until warmed up. The PFC's seem fine. The PFC 08's also seem to have a smoother initial bite which results in less ABS for me.
I love the PF 08, nice and silky feeling and strong, and actually work OK cold so I can leave them in for autocross or street tuning. They did seem to make a rusty mess on the insides of my rear wheels but that could have been from new rotors bedding in.
they do make a mess.. ive really liked the PFC11s for racing and on the track, they are fine too. no complaints when bedded correctly / completely
they must be a good pad, since most of the cup cars ran on them for many years.
try the PFCs when you get a chance.. amazing pads.
Hi
Thanks for all the info and advice on this subject, My car is not a Porsche, its a BMW M3 but I was finding very little about what people recommend on M3 forums other than everyone uses RS29's so done a search and this forum came up and the knowledge on this Forum seems a lot better regarding track use.
Im running Ferodo 2500's now but now really happy with them as the bite isn't great if I'm honest and the pad doesn't give confidence. I'm very limited with what Pad I can use for my Brembo Calipers, my options only seem to be PFC08, RS29's or Carbotech XP8/XP10's
I need to check to see if I can get the DS1.11 for my caliper
Thanks once again for eveyones help
