Brake fluid concern
if the fluid came from a sealed container, and you trust the "yes it did" answer your shop gives you ...... it should be no problem for a DE.. it's not like wine that goes bad after 100 years. its brake fluid. as long as the container wasn't opened for 8 years......and for a DE .. should be no problem.
Peter
I don't believe GS610 has been manufactured for over 8 years. Last time it was produced the investors dumped the business partner and took back significant inventory. They have been selling in small amounts ever since. We had some tested three years ago and the boiling point was significantly lower than specification, like really bad. The bottom line is that brake fluid goes bad in sealed packaging. You need to buy it fresh.
but, if you paid for the good stuff...certainly worth a complaint and a re-fill
no, you are not going to die. worst case, you might get a spongy pedal!
No ****... Brake fluid isn't a magical elixir, if it is sealed it can not absorb much moisture and it's age in the sealed bottle (within reason, i.e. a year or less) is not an issue. Personally I think anything but Castrol SRF is a death sentence at a DE, but I tend to exaggerate..
Bottles absorb moisture. In the Phamaceutical Industry you perform Moisture Permeation testing on the container/closure system. Or they did not control the manufacturing/filling operation. I would stick to a brand that has proven history.
I think it's not so much that the bottle absorbs moisture as much as it is that the bottle is permeable to moisture. Moisture permeability isn't unique to the pharm industry, which I suspect also tests for oxygen permeability. Even beer makers do container and cap testings. Picking the right container with or without a barrier isn't rocket science. I would think any company selling brake fluid would be cognizant of that. Now I have to go out to the shop and look at brake fluid bottles...
According to Motul, unopened brake fluid does have a shelf life - either 2 or 3 years, IIRC. They recommend storage in lower humidity areas i.e. in the heated basement rather than the garage. I also store the unopened bottles in ziplock bags, and understand I have a healthy paranoia.
What he said
I have been party to test data showing the effect of time on the performance of brake fluid. The tests clearly show that brake fluid in sealed containers absorbs moisture and degrade in performance in a linear fashion over time. All the fluid companies know this.
what did your "tests" find?
"linear fashion" meaning, if it lost 10% the first year, it would be 10% every year after that?
are you talking boiling point? wet/dry ? compresibility?
did you test both metal and plastic bottles? (KEY POINT)
Again, we are talking DE here. we are not talking a GRAND AM enduro race.
stock fluids are a little week and are not recommended for the track. but brake fluid kept in its container for a few years is not going to be a problem, if unopened..........just as fluid in your system exposed to heat, air, condensation, etc, isnt a problem for a few years either.
think about it... you buy a GT3 cup car from 2015 that right from the factory. would you worry about changing the brake fluid.. heck that has been open bottle for 3 years! how about a brand new GT3.. might be up to 1 year old.. that fluid has been basically in an open container with the lid off!
you guys are getting a little mental over all this. like the Nitrogen for DE discussion.
key point though, is if you are talking steel container, vs plastic. steel, unopened will not absorb any moisture. (other than what it was sealed with)
Many brands like Stoptech, even since SuperBlue, come in metal containers. you cant compare the two.............or did you do tests with both???
if you were "party " to the data showing the effects of time on brake fluid "performance" and the test's data was "clear"...........
For this inquiry it is not worth digging up the test data from three years ago. I recall it being surprisingly bad. Dry boiling and also alkalinity changes. Wet is wet.
8 year old brake fluid in a sealed container is nothing more than hazardous waste. It should not be in a tracked car. Nobody is mental over it, the original poster asked if GS610 could still be in production or good if old. The answer is simple, No.
Addict Rennlist
Bill
OG Racing
Your Source For Motorsports Equipment
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Sparco's Largest Distributor for 28 Years
PFC Distributor for 27 Years
Pagid, Alpinestars, MOMO, OMP, Hawk, Bell, Aim, G-Force, HJC,
HANS, Arai, Simpson, Brey Krause, Longacre, CoolShirt!
Supplying Track Junkies for 34 Years.
PCA Club Racing - National Sponsor Since 1998
A Veteran Owned Business
Check out our blog!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Check out our blog!
