Nannies or not? HPDE instructors weigh in
#46
Originally Posted by winders
I suspect most newer track drivers have no idea when nannies engage and what they do for them. The more transparent the nannies the more likely this is to be true. Also, unless the instructor is eyeing the dash constantly, he is not likely to know when nannies kick in.
I even find it hard sometime to see it from the right seat. If I can, and it's appropriate for the student, I'll tell them when it flashes.
It's a shame we often use the term 'nanny', which implies much more negativity than it deserves.
#47
The point was and is what do we as instructors tell drivers regarding these systems (not only from a learning curve perspective but also from a safety and personal liability perspective as well)...not what is best for you and me when WE drive on track...
#48
Actually, you didn't.
You are arguing a different point.
#50
Actually, I did.....
But to the original question that kicked off this thread, I think nannies on to start with is probably safest and depending on the car and the drivers track objectives, they may stay on forever.
#52
Those of us who learned to drive with no aids & saw things like power steering, ABS, and the progression of electronics introduced over each generation of car is completely different than today's drivers. As Coaches we know this. New Instructors often don't. New drivers, new cars. Leave them on.
#54
Another train of thought... Cirrus builds the SR GA aircraft with a parachute system just in case. It has already saved hundreds of lives and I am pretty sure nannies on the track have as well.
If you were a flight instructor would you force someone to disable the parachute so they can learn the ramifications of pilot error or would you quite possibly want to have that parachute there but teach them not to fly themselves into a situation where they need it? Would you force them to learn an engine out landing if they have an unforced engine shutdown on their 2nd lesson or be happy to pull the chute and discuss procedure on the ground in one piece instead of 22?
#55
I drive with the nannies on in my GT4.
it allows plenty of leeway and based on what I have heard from others you need to be at the Porsche factory driver level or close to squeeze that last .1s out of the car that the nannies don't allow you to get.
so with performance out of the picture the nannie is a very efficient insurance policy (and yes I used it once in the wet to prevent a sure write off; lesson learned....)
having said that, you I still don't use them as a cure all safety blanket. I try to deal with nannies by evaluating myself in every corner.
not just nanny intervention, but abs for just 5 clicks, front or back sliding minimally without nanny kicking in yet etc.
for all of these its important to understand what caused it to happen and whether you wanted it to happen...
doing this will finetune your butt dynamo as you will continue to look for smaller and smaller missteps.
The big one is usually preceded by many smaller ones, not only in this corner but in previous laps in this corner and in other corners
#56
#57
I find most new drivers in newer cars don't really show much interest in turning them off, and if they ask me I'll just say let's go ahead and leave it on for now. There is plenty to learn when some one is brand new to the track.
#58
I think its pretty dependent on a lot of factors.
IMPO
#59
i'm blown away, literally, by neophyte drivers in 991 GT3s as their cars dance through the corners in attitudes that initially make me cringe.
good on the SW developers!
I always ask my student to leave the SW aids ON for the first few sessions as we feel each other out.
Craig
#60
WRONGLY ACCUSED!
Skid pad is invaluable and not enough people do it. Hell, I have not spent enough time on the skidpad but at least I have done some.
