3000rpm in 3rd gear or 4000rpm in 2nd gear?
If you're on a long section of windy road where you're mostly 3000 rpm in 3rd gear (around 45mph).
Would you put it into 2nd where you'd be driving 4000 rpm in 2nd gear?
Just feels like driving along at 4000 rpm seems a bit much.
Received 5,413 Likes
Are you on a road or a race track? Your redline is probably well over 7,000 rpm. Stay in the lower gear.
My $0.02
For just cruising down the road (and better gas mileage), 3rd gear would be my choice.
For performance driving, life begins above 4k rpm and starts to get exciting above 5k rpm.
Wrong forum......
Don't you find it very hard to drive at 4k+ for any extended period?
Rotating the car, throttle steer, and precise car control all happen above 4K (even better above 5K), but you don't need any of that on the open road... save it for the track.
WRONGLY ACCUSED!
I'm thinking the same thing.
But if this is the right forum the above would be the answer.
Don't shift until your shift lights are flashing!
the reason for this is that you then have maximum accel and max decel forces that the engine can make with NO other pedals involved. if you ever are at a speed where the engine is out of the highest HP range (range of your gearing) you are sacrificing the ability to use these forces. if you are worried about , spinning out because of too much force , or controlling the car, learn to do that then!
yep... one of the nice things about the 928 is that i have that racing-useless, 5th gear. but it sure was nice to cruse to the track at 2000rpm going 70mph and get 20mpg (a lot less noisy too)
5th gear, that's so 1980's. Now days you use 7th gear to lumber to and from the track
