How often do you replace your trailer tires? How about the spare tire(s)?
Time to replace mine, which are 4 years old. Goodyear Marathon D rated which have served me well.
- How often do you replace yours?
- Are you located in the sunbelt (I am in New England)?
- Do you replace your spare(s) at the same time (my spare just blew out)?
- Would you buy a Goodyear Marathon D rated tire or a Power King Towmax E rated tire (ignore price; only interested in longevity)
- Do you cover your tires against sun damage?
Thanks - would like to reduce the frequency of tire failures. They happen at the most awkward times and places. My latest was in the Adirondacks late at night with minimal cell service.
Basic Site Sponsor
Basic Site Sponsor
Received 2,801 Likes
Rick, you're already taking the best step to prevent untoward and unscheduled failures on the road by adopting this proactive policy.
I just did the same thing, replaced my Marathons with TowMax one load range higher after four years. That's the recommended interval. I live in a hot place and do not cover the tires, although I will with the new ones. See you soon!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
So, as far as trailer tires go, i think you should replace them every 5 years. (you know me.. ill probably go 6-7. and ALWAYS carry a spare! I cover the tires in the backyard now too. I went to radials (Towmaster Trailer Tadials) from the bias ply cheapo that came on the trailer ST5000s .
interesting that the new radial trailer tire pressure is 50psi too.
WRONGLY ACCUSED!
Received 3,242 Likes
I do not replace the spares at the same time and let them go a lot longer. Mine are inside the trailer protected from the weather and sun. I inspect them for dry rot and pressure from time to time. I carry two because if you run over something there is a good chance you take out both on the same side.
Goodyear Marathon.
I have the covers but use them about 25% of the time during the summer but they are on for the whole winter.
I also have a drive on trailer ramp. Instead of worrying about jacking up the trailer you place the ramp under the tire that is still inflated and drive up leaving the other one suspended.
My rule is I consider the safety of my trailer equipment equal to the safety in my race car. At speed a failure in either can be dangerous.
Proactive replacement every 3-4 years is the way to go. Also, meticulous monitoring of pressures before each tow is important.
Trailer tires ALWAYS blow out at night, in the rain where there is no shoulder on the highway or cell service
Rennlist Hoonigan
which cost no drachmas
We run the Towmax and replace them about every 4 years. They still have a ton of tread, but it cheap insurance like others have said. We do the spare at the same time. We also cover the spare all the time and cover the trailer tires when it's sitting.
going to radials, did that help my situation for risk? why bias ply vs radials. the tires seem much more durable , but that is just the appearance .
my question is the same.... is the trailer tire a special type of tire? why not just a tire of similar size?
I just swapped mine out at 3 years with maxxis tires. Supposedly they're one of the better ones, certainly more money than the comparable good years.
Discount tire direct has a $160 rebate off trailer tires this weekend assuming you use their credit card, if you're due for a change it might make sense.
I thought about going with LT tires but that would require new rims, and I worry about screwing up the height / offsets with a new wheel combo.
If someone has done it with an enclosed trailex I'd love to hear what they went with.
I
Amazon.com: Trailer Aid Tandem Tire Changing Ramp, Black: Automotive
thanks for posting
There's a great explanation on discount tire. Here's the link
http://m.discounttire.com/dtcs/infoTrailerTireFacts.do
And here's their take on ST tires
Why Use An "ST" Tire
"ST" tires feature materials and construction to meet the higher load requirements and demands of trailering.
The polyester cords are bigger than they would be for a comparable "P" or "LT" tire.
The steel cords have a larger diameter and greater tensile strength to meet the additional load requirements.
"ST" tire rubber compounds contain more chemicals to resist weather and ozone cracking.
Thanks everyone for your input.
PETER and MATT - did you go with TowMax for the higher load rating (E instead of D)? The price is lower but that's not a priority for me on this purchase.
Rennlist Hoonigan
Judy and I went with the Towmax for 2 reasons - 1. The guy at the RV place (the people who use the most tires like these) suggested them as almost equal to the Goodyear for a much lower price 2. We figured for the money saved we could just replace them more often. We got ours at VIP for a really reasonable price.
