Considering move from Hoosier R7 to Hankook Ventus Z214 51
Originally Posted by Martin S.
As stated earlier, Z 214 tire were gone in less than a day, 3 run sessions of 25 minutes each. Put on the Nittos NT-01, and the wear across the tread was fully acceptable. Can't recall the exact negative camber on the rear....I know that Hoosier recommends their R6 be run with -3 degrees of negative camber.
One last tidbit, I took out some 10+ heat cycled NT-01 tires in the rain. They were fully predictable.
Stick with the Nittos, more Hankooks for me. But don't knock the tires because your car wasn't set up for them.
Rebuttal of sorts....
"But don't knock the tires because your car wasn't set up for them."
I just don't have the records of the negative camber set up on the rear at that time the tires were cooked in just three (3) sessions. But on a previous set of
Z 214 tires, I got nine (9) heat cycles before they were done. The wear was pretty even at that time. Nine (9) heat cycles is about what I get out of a set of Hoosiers before they revert to practice tires.
BTW, for the record, I drive a 3,200 Lb 993 with MCS suspension, all the trick stuff that goes with it. Since you have had success with the Z 214, what camber is recommended front and rear? I didn't see that on Hankook's web site, or anywhere else for that matter.
I will stick with Nittos because they are the most economical alternative, 33% cheaper than Hoosiers...and they last at least 2X as long. Agreed, they are not the quickest tire in the hands of one particular driver...I just need to learn how to drive them faster...and that's wear my AiM MXL-2 comes in to play.
And lastly, I do feel I am justified in knocking them because of their inconsistent supply chain. Perhaps the best thing to do is buy multiple sets when they become available. That's just not in my budget, I am a hand to mouth track guy and buy one set at a time.
From Discount Tire Direct's Web Site:
"The Hankook Z214 Road Racing C51 is not currently in stock....However, we may be able to order them in for you. Please call us at 800-589-6789 for availability and price." Well I called that number, talked to Jeff at X518, wanted to see how long the wait would be for a set. Guess what? The Z 214 C51 has been discontinued, no longer available. It would seem the Z 214 tires are now moot, sad news for those that have embraced them.
The are NLA according to Discount Tire Direct. The factory has discontinued them. Sad news for their supporters.
IBTW, for the record, I drive a 3,200 Lb 993 with MCS suspension, all the trick stuff that goes with it. Since you have had success with the Z 214, what camber is recommended front and rear? I didn't see that on Hankook's web site, or anywhere else for that matter.
I checked either Tire Rack and they are reporting that the 214/c51 is still being built and that they are still available for order, though there may be some on back order.
Will report back if I hear otherwise.
We placed an order for 12 tires in March for Hankooks ... update from Tire Rack was that we would get them mid April as they were on the boat ... next update was they weren't on the boat and they would be available end of May !
My season starts in two weeks , we ended up getting TOYO RR's as they seem to be the spec tire for a lot of series.I just can't justify the price of Hoosiers by the time they get to Canada !
We're talking $400.00 dollars per tire for 225/45/15 's
No complaints about that life out of the Kooks. I'd still be running them if I could get them.
I'm trying Hankooks as a Hoosier alternative but with this level of service it's going to be tough to earn my business.
Rick,
Alain and i will be scrubbing our new shiny TOYO's at LCMT next week ... looking forward
to chasing you around the track ... lol
I had nice results with BFG R1's on my 911,about the same time you had your black car.
Not sure if they come in your size though !
I tried c51 for first time at lime rock PCA club race this year.
They were fast (59.3), but r7s feels better.
On 944 no issue on rears, but fronts were almost done after sprint 1, started sprint 2 on stickers - done ! Not much rubber left.
Going through the exact same deal with street tires.....B'Stone RE71R is this year's autox tire of choice and TR is out of stock 'til the end of the month. Had to get StarSpecIIs--if anything, they'll wear a bit better.
Been running them for a few years successfully with plenty of podiums and class records. They last longer and are faster longer then R6 & 7's IMHO. Downside: 1. Order up the whole season and hope they arrive (placed my order - Feb 15). 2. They need a lap to really get sticky. 3. Sizing is limited, but fit my car perfect!!
Tried R7's at WG last yr, seemed quicker then R6's and lasted longer, but not Z214 quick, so relegated them to practice sessions. Maybe I'm just used to Z214's, and change is not my strong suit I have only corded front tires, and on short tracks like Limerock, you need to swap sides after each session, and after 15+ sessions they are done or close to it. My camber is ~ 3.5 F & -2.5 R (need to double check R) I have never fried set of tires in one sprint, ever and would be spitting bullets if I did. Something else is wrong for that to happen, IMHO. If you are a Z214 "hater" have at it, more for ME.
Are there any issues with the Hankook Z214 tires on banked tracks like Autoclub Speedway? I'm looking for an alternative to Hoosier R7s for an upcoming event at ACS. Do you need to adjust camber or right rear tire pressures with the Z214?
