Lower back support
Lower back support
All,
I have a sensitive lower back, racecar seat doesnt help.
I recently injured my lower back and need to have a some sort of support to keep my natural arch while in the car to keep it from getting exacerbated.
Suggestions?
Suggestions?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Best solution would be pouring a SFI Foam or a bead seat.
Also the Backsaver pad seen here at Pegasus is awesome for this as well.
https://www.pegasusautoracing.com/pr...asp?RecID=1059
I just had a Speed Seat poured on Saturday that is custom made to your body/seat combination. They were very professional and have made seats for many pro drivers. They pour track side and finish at their shop and send you your custom insert.
http://www.speedseatfactory.com/Full...t_Process.html
I probably have the same pad. Interestingly, putting it behind the seatback padding (rather than between my back and the padding) seemed to exaggerate the benefits. You might want to give that a try.
The process begins with removal of all the the existing padding in your race seat then a thin, dense foam core material is loosely put in the seat. A large plastic bag is then put over the seat and filled with flame retardant liquid polyurethane at this point the driver sits on the bag of liquid and the liquid foams and expands around your legs and all the way up your back. You sit still for 10 minutes to allow the foam to harden. The insert is then removed and excess foam is removed and then placed back in the seat and you check it for fit and comfort, small adjustments can be made if any areas don't feel right. This rough shell is then returned to their shop and professionally finished and covered, your name is sewn in for ID with teams with multiple drivers.
The insert isn't cheap, about $2200, but to be custom fitted into your car/seat and drive without the pain of a stock seat - you make the call. Professional drivers have gained 1-2 seconds in lap time as a result of feeling "planted" in the car.
I don't have any affiliation with this company, but they did a great job and are very customer service oriented. Jody is the owner and pours most of the seats he's a former racer so he speaks from experience.
With the Recaro/OMP type seats, you can put pads behind the normal back pad as someone said above. I put a LOT of padding there as my back is very bad, and it really helps me drive and not get tired.
Basic Site Sponsor
Basic Site Sponsor
Received 2,827 Likes
I have SEEN this kind of time improvement from experienced drivers (and pros in cars new to them) countless times.
If you're thinking of how much you hurt, you can't devote all your attention to driving well and fast.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
