Trailer Question
This will vary by car and trailer, but I've found that placing the side mirror directly over the front axle is a good starting point to balance the tongue weight. And as mentioned above, add tires to your rack, and you'll need to move your car further back on the trailer.
Way too much weight up front. I thought I read that axels can be moved some on the trail floor for Trailex. If it was set up for a 911 (weight out back), then the trailer set up / load in needs reconfigured for front end motor car.
Suggest you buy a Sherline scale to measure it and be safe. You are already likely exceeding the rating of your hitch. When you load tires on the rack later, you will need to move your car even further aft to maintain the correct tongue weight.
I bet this solves your problem.
+1 Very much agree with this. Carl will tell you their trailers work fine for most cars. But the axle placement was based on carrying a 911. I trailer a Cayman (mid engine) and I have to load it just about as far back as it will go to get an appropriate tongue weight. It will be interesting to see if you can balance that trailer with a Corvette on it. Keep us posted.
I didn't say add it. I said to check it. Based on the picture, you will find out that your tongue weight is 1500+ lbs when it should only be 500 - 750 lbs. Suggest you buy a Sherline scale to measure it and be safe. You are already likely exceeding the rating of your hitch. When you load tires on the rack later, you will need to move your car even further aft to maintain the correct tongue weight.
Yes I do agree, car needs to move back on the trailer. It was the first time on there so I'm still getting it figured out. My truck was sagging 2-2.5 inches, and from what I understand, my Raptor leafs are ~180lbs/inch each. Tongue weight was definitely too high.
Thanks again to everyone, this thread has been very helpful.
I did notice that the axles are pretty far back. I haven't seen how they could adjust but I am going to look into that.
One other thing, I have only used the winch once but it looks like the winch stand has some stress marks. I asked Carl about this and he said it is just the result of them bending the parts in house, but I don't know if the pictures came through clearly enough to show the marks I was talking about. I also didn't want to keep bothering.
Could anyone share an opinion on this:
Something else to consider: the nice thing about these lovely Trailex bolted haulers is that you can adjust the front chocks.
Once you identify your spot (maybe best done w spare wheels on the rack) may try repositioning the chocks so it's a no brainer next time.
Yes sir - absolutely. Looking forward to getting it all setup and automatic.
Thanks much!!
I put it back on the trailer today about 6" further back. Tongue weight seemed better (was not able to measure) but the tires did not rub or anything. I am going to flip my receiver over, which will help too.
After moving the car back, I ran in to a problem where the rear D-Rings were too close to the tires. I decided to cross them in the rear this time but I am going to see if there is any way to move the axles forward. I would be much better off if the axles were ~6" forward of their current position.
Thanks much!!
