Cayman Spec vs GTB1
Cayman Spec vs GTB1
Ladies and gents,
I'm at a crossroad and would like to hear your opinions.
DE has been fun but missing something. Therefore, I would like to go back to racing. I'm considering either a Cayman Spec or a GTB1.
I would start DEing the car and make it evolve to a race car (I know it's cheaper to buy a built one but like projects and the idea to improve my skills as the car improves as well).
In order to buy the right platform, I would like your opinion as to which series enter. Cost is obviously an important consideration. Could someone tell me the ballpark cast for a season in both categories?
Also, which is more fun? Which has the biggest field (East Coast Canada).
Anything else?
Thanks a lot in advance!
Anything else?
From what I've seen/read, to run at the top of GTB1 you will be spending a lot of money, especially if you don't buy one that is already built race ready.
The spec cayman class is a new class this year, but it is much easier to build one and it will cost you much less in the long run. To build you can simply follow the spec sheet on the 2016 PCA club race rules and regs document and build at your own pace. Being a spec class, I see it growing a lot in the near future and the racing will be a lot more competitive/fun than gtb1 which can be seen as more of an arms race to run at the top.
Right now the field size in gtb1 is obviously larger, but I'm sure the spec cayman class will catch on very quickly just like the other spec classes have.
There are a few guys building spec cayman's right now that I'm sure will chime in to give you a realistic budget to build one.
Tons of info in this thread.. I recommend reading through it.
https://rennlist.com/forums/racing-a...class-spc.html
Spec Cayman: This is pretty much an Gen 1 (2006/2007) Stock H Class Cayman S that can be bought already built for $50 - $60k with a spec suspension and tire package. You can also buy a basic Gen 1 DE Cayman S with all of the required oiling and cooling mods already done, install a cage and run Hoosiers and work weight reduction from there. You might start racing in H Class until the Spec Cayman field gets bigger. Stock H is currently a decent class but it really depends on which part of the country you plan on racing. Spec Cayman is a developing class and there is some risk that it might never really develop.
My sense is that a racing weekend will cost you the equivalent of 1 - 2 sets of tires, a set of pads and a about $200 worth of fuel plus registration and lodging.
GTB1 is a whole different story. There are some very talented drivers you can learn from in this class plus the fields are relatively large. Those two aspects make it the most fun for me. There is only one person I know of that competitively races a Gen 1 Cayman in GTB1. This means that you are looking for a 2008+ Gen 2 car, preferably with PDK as PDK cars are much more competitive on most tracks (even with the 100 lbs extra weight penalty). If you prefer a 6 speed car, the Bosch Motorsports ABS is from my perspective a worthwhile differentiator to PDK cars (which cannot instal it since the ABS requires the wheel speed sensors that are used by the ABS). This comes at a cost of about $15k installed and gives you a clear advantage. Most people spend a lot of money on weight reduction to get to min weight. This includes carbon doors, hood and hatch. Carbon Fiber is expensive!! There are many ways to make your car more competitive through weight reduction, electric power steering, etc… It's all pretty expensive. Suspension and brakes are free - so there is tons of money to spend on that too. Tire choices are Yokohama or Pirellis with the later being more expensive and slightly faster.
For a race weekend, the fastest folks use 2 - 3 sets of tires plus…. Given your ability to run a more sophisticated suspension set-up, you will also spend more time testing, tuning and on set-up.
The above estimates don't account for the cost of your Pro Coach, track support by a race shop and any sort of $$$ damage allowance. Theoretically, you can buy a Gen 1 Cayman, start out in Stock H, run in Spec Cayman once the fields get larger and/or upgrade to GTB1 spec later. Subsequently you can install a 3.8l in that car and run in GTB3.
There's no escaping costs with a p-car. I think by the time I was done with my 986, I could have bought, restored and driven a 935.
WRONGLY ACCUSED!
Beyond that the answer to the OP's question is what Frank said.
GTB1 is for powerball winners and Spec Cayman is for lottery winners. Either way you will be shelling out the money!
Originally Posted by jdistefa
The Spec tire is the Toyo RS1. One set per weekend is a reasonable assumption.
^ Frank - scrubs from previous weekend(s) are used for test days and practice. Fresh tires Saturday morning, scrub-in for warmup, 2 sprints, and enduro. Rinse and repeat.
The Toyo slicks are supposed to last for a while. I tested them and after about 12 heat cycles I put in my personal best at Lime Rock.
Thanks a lot guys for all that great info!
A few things. when i said cost is important, I meant that I'd rather go the cheaper route if the fun and experience is the same... I understand that Porsche racing isn't a winning proposition when it comes to money. I also meant that if it's cup car money as some mentioned, I could be considering a cup car instead. And finally, if running costs are cheaper, it means I can have more seat time which I think is the most important part of the equation at this point for me.
Another consideration for me is the gen 1 vs gen 2 debate and most importantly the reliability aspect of said gen 1... Blowing an engine in the first practice probably means no more racing that weekend which again goes against the idea of as much seat time as possible.
Also, nobody is mentioning building a GTB1 on the latest platform. Why? Is it becuase new cars are too expensive to start with?
Finally, I too am surprised by the tire choice for SPC. I was expecting something cheaper, longer lasting and that wouldn't put as much stress o the gen 1 engines.
Keep it coming!!
Keep it coming!!
You asked about GTB1 and the latest 981 platform is classified in GTB2 and there are ample examples of cars that have been built. However, the run groups tend to be relatively small in GTB2 as all 911s have now been moved to GTB3.
Patrick3000 (08-23-2021)
