Profi II-6 HANS or Enduro Harness
Is it possible to order the Enduros with the Gt3/LWB lap belt fitting hardware or must they be ordered separately?
GT3 Hardware
The GT3 specific belts come in straight from Germany with the factory bolt-in hardware on the belts. Schroth does offer an alternative by getting a B23 bolt in bracket - they are $12.95 per end. The only thing is, you may have to use a washer to tighten up the hole to fit with the factory bolt in the GT3.
Schroth can also custom make profi belts with special tabs and ends similar to the enduro - but you might as well go with the enduro by the time it's all said and done.
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
I received my new fresh dated Enduro belts today. Very nice as always, adjustments are silly easy. One problem, they were supposed to be the new red not black. I'm sure they will clear it up.
which B23 bracket do you recommend? Also, what size washer? Thanks
B23C or B23B?
B23B
B23C or B23B?
B23B
