Mid Ohio - Help me find time +Video
Hopefully they'll fix it before spring, but if you're attending this weekend's track event be aware.
Gary
A 10hz external GPS for ~100 dollars dramatically improves the quality of data output from Harry's. I couldn't be happier for what I'm getting from a less than 150 dollar investment.
This is a pretty cool thread. And I'm almost convinced on posting and asking for feedback on my own video...
Be careful going over the inside curb at 11 (Thunder Valley)......not only is the grass gone but the dirt is as well--there's a big hole there and you don't wanna hit it. Upsets the car big-time....ask me how I know
Gary
Gary
Turn 13 is really entered early. There is a hole/rut at the beginning of the curbing, you want to be on that hole (it's small). There used to be good braking markers on the fencing, above the Armco to the right as you enter 13. However, that Armco took a beating earlier this year and had to be replaced. I noticed this weekend the brake markers/numbers no longer exist. If you can find some older video, I always used to just brush the brakes at the "2", and turn in at or before the "1".
Come to think of it, the brake markers are also missing from the fence on the left entering China beach at the end of the back straight.
try and put the camera back so that we can see steering input. To help, we need to see that to see if you are scrubbing speed off in or out of turns. The lap looked smooth.
The weather this past weekend was amazing!
That event was my first visit to mid Ohio. So I can't offer a whole lot of constructive feedback. But it looks like you're trying a bit too hard to set up for madness. You can carry more speed through China beach...there's tons of track still to your left on exit.
Also, ignore this advice below...I had no idea how nice an AIM solo was until this year...
A 10hz external GPS for ~100 dollars dramatically improves the quality of data output from Harry's. I couldn't be happier for what I'm getting from a less than 150 dollar investment. This is a pretty cool thread. And I'm almost convinced on posting and asking for feedback on my own video...
Basic Site Sponsor
Basic Site Sponsor
Received 3,339 Likes
Without data or at least info on the video, hard to tell and harder to compare. All you can speak of without that info is generalities...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I was signed up and in Ohio when I got a call Thursday night and had to come home--bummer . Spooky, as near the end of the video you passed a white Mini that looked just like mine
Anyway, on the whole things looked real good to me; you really don't need to hit the first apex in the chicane--stay out a bit and you'll get a straighter shot going into the Keyhole.
Keyhole--IMO you're going way too high and spending too much time in the turn, and you're almost running out of track at exit anyway. Try mid-track through there if you can and see where you come out; check your exit speed at the end of the exit curbing. Same for the Carrousel but it's not as pronounced as the Keyhole.
Otherwise, just hit/miss stuff--Madness seemed much improved over last time but make sure you hit the apex for T9 i.e. on the curb.
Again, I'm the farthest thing from a pro coach and drive a completely different car than you so do with these what you will
Gary
Gary
Basic Site Sponsor
Basic Site Sponsor
Here's the data lap if you want it. I'm finding Harry's Laptimer just isn't accurate enough to deeply compare, but it is what it is.
What I'm doing differently this event-
T1- I made a serious effort to be as consistent as possible braking at the 200 mark and turn in, allowing me to get to full throttle sooner, and more comfortably. This resulted in higher exit speeds.
T2- I worked to carry more speed through 2 by being consistently on the apex curbing to straighten the braking into 3.
T3-4- After braking at 3, back on throttle to braking before the Keyhole. Carrying more speed pushed me wider in the Keyhole.
T5- (Keyhole) Worked to be on the throttle sooner through the keyhole, getting used to the back of the car drifting a bit down the hill and being full throttle much earlier.
Back Straight, better exit from the Keyhole = +3MPH at braking zone.
T7- Tried carrying more speed and running wide to be tight for T8, but preferred exiting T7 about mid track to carry more speed over T8.
T9- Sometimes on the curb, sometimes not. Full throttle at T9 apex through T10
Going over the hill, I usually feather back slightly. Tried it a couple times at full throttle and it makes braking at T11 a little dicey.
T12, same as always, try to be on the curbing.
T13- Worked on less braking, more consistetly, full throttle through apex to Carousel braking zone.
T14- Tried starting wider into this turn and being full throttle well before apex. Seemed to carry a lot more speed through this section on to the front straight.
Nice driving! For what it's worth. Tommy Byrne said not to cross over the "center line" in both the key hole carousel. He felt that this was the right line for any car.
BTW - you were two garages down from me last weekend (black 996). Your white GT3 is beautiful.
Basic Site Sponsor
Basic Site Sponsor
+1 on the above. It's easy to go too hot into the Keyhole and Carousel and end up too wide. You just have to have a little discipline.
Some teach a wider line but I prefer the "left side tires no more than half way out" line, probably due to habit after many years of SCCA racing at M-O.
Been running, teaching and winning at Mid-Ohio for nearly three decades in a variety of different historic and current cars, and I recommend placing right side tires no further left than centerline, after driving over it.
I can see how in a less responsive car, you might not be able to get down to the apex, especially if you overcook it.
I love Tommy and he has a lot of laps as head of the school there
But, if the rotation is quick, you don't lose time and there is an advantage in "sooner to WOT" on exit, according to data from cars turning 1:19 to 1:55...
YMMV.
