chassis rake?
Guys,
I am lowering a car right now keeping the chassis rake stock. However, I would think that you could improve high speed braking by lowering the rear just a bit on a rear or mid-engine car. This would change the weight transfer in positive ways I think. What compromises does an OEM make when setting up stock chassis rake? I would think that braking would improve when nailing brakes right before corner "turn-in". If this does help what will I give up? There is no free lunch. Any opinions?
TIA
TIA
hello fatbilly, sounds like you are thinking suspensions. advice won't help until you try the new lower height, there alone is a change in geometry as far as corner weights go. if you can, do a full alignment after the spring changes, and possiblbly check corner weights. i've seen rake between .8 to 1.4 degrees positive, without complaints. good luck.
