Going to open trailer from enclosed, arrrgggh!
#46
WRONGLY ACCUSED!
http://pitboxes.com/pitboxes/
https://www.irvansmith.com/scart/wag...-24_63_72.html
http://www.pitpal.com/images/custom/...l19catalog.pdf (page30)
#48
I looked at commercial pit carts but could not find any that did what I wanted.
Had to roll up the trailer "sideways", I don't want to fight with it every time.
Had to "clip" in place, again don't want to fiddle with a bunch of straps. Should “click” into place and go.
Had to hold enough n2 to fully inflate a tire. I don't want to have to depend on power for a compressor.
Had to have room to store my tent.
Had to have room to store 1 set of spare tires.
Room for a few tools and spares.
Has to be the permanent home for all this crap in the garage. I don’t want to have to “pack” before I go to the track.. Just roll it on and go.
The box is ¾” marine plywood top and bottom, and ½” sides.
Its covered in laminate (obviously)
The aluminum corner protectors also seal the corners, there is a bead of silicone underneath.
The latches, hinges and wheels came from irvansmith.com. These guys have lots of cool stuff.
I can’t find where I got the aluminum z-channel for the door frames. It took me a long time to find it the first time, and I’m not finding it quickly now. I used ¾ since the doors are 5/8 (with laminate), that leaves another 1/8 for weather-stripping.
I was really (maybe overly) concerned about over stressing the box as it bounces down the road.
I didn’t want to bolt the wood box directly to the rigid metal frame. I wanted to have some flex to match the movement of the tires. There are rubber isolators where the frame joins the box. http://www.greenerubber.com/wp-conte...ng-bushing.pdf
Internal to the box there is webbing behind each mount point to distribute the load.
All wood joints are very tight, glued and screwed.
Three is a vent just in case the n2 leaks, otherwise it is air tight.
The doors are thin not only to reduce weight, but if there was a catastrophic failure of the bottle, the doors will give way and provide a large vent.
I’ll take some more pictures this weekend of the inside.
#51
I now run with a stiffer rear bar...don't want to change the springs. Too much hassle and expensive...and I now run on Nittos NT-01, not quite as much grip as the Hoosier R7.
