AiM Sensor Feeds
#31
Rennlist Hoonigan
which cost no drachmas
OK Matt, Jerry and Peter: I'll bite.....
What sensors and inline couplers would you recommend for a 2001 GT3 Cup? I would like to be able to measure and report the following:
1. Oil pressure
2. Oil temperature
3. Water temperature
4. Coolant system pressure (lots of great suggestions from folks to monitor this value - thank you!)
5. Coolant level in expansion tank (a simple OK or low value, like an idiot light)
6. Fuel level (already dealt with via an ICM fuel sensor)
7. Throttle position
8. Crankcase pressure, eventually
Which AiM sensors do you recommend and what couplers/adapters/fittings should be used if I am trying to retain existing feeds (to preserve the car's legacy - yes, I am a NUT about that kind of stuff. This is why I am trying to tap into existing sensor feeds where possible.).
1. Oil pressure
2. Oil temperature
For oil and water temp, the standard PT-100 temp sensors are the way to go. Inexpensive and reliable.
Throttle position can vary depending on how you want to do it. For the easiest instal, you can do a string pot. You can also do an "arm" type sensors or a rotary pot at the throttle body. This really depends on how you want to do it and how much time you have.
For crankcase pressure, you can use the factory setup like Jerry has figured out, or I have another way to do it that I've figure out. Jerry's would be more or less plug and play on your car. My way would take finding a couple of fittings and install. Both would give the same results.
For the coolant level, you really might be best off tapping into that sensor. It should be easy to do and I'm happy to walk you through the basics of what to do so you can put it all together.
Now, for how to tap, there are lots of options. For coolant temps, you can see if there is a spot on the engine to put the sensor in or you can put one of these in a coolant line. There are a ton of people that sell similar taps for the coolant lines.
Same deal for the oil lines. If you don't have a spot, you can use one of the unions like here http://www.anplumbing.com/Extras/Gau...apters-62.html
#32
924RACR, normally, I would agree with the driver development aids.
However, the MXL2 sits directly in front of the stock gauges and thus I cannot readily see any of the gauges or idiot lights on the dash. I'm not necessarily interested in logging these values as much as I would like to trigger alarms and warnings on the dash itself.
#33
Thanks for the recommendations Matt. I appreciate it very much.
Toby
Toby
#34
Rennlist Hoonigan
Personally, I'd just use a switch for an idiot light for water pressure - and do, on my car, sourced from Longacre direct. After all, it's not something you want to log and analyze after the fact - you need to know about and react to immediately.
Similarly I wouldn't rate fuel level as something that needs to be logged, just checked between sessions.
Rather, replace those with steering angle and brake pressure... much more useful for driver development.
I would definitely log fuel level if possible. You could do a lot to find optimum fuel loads. Just think about looking at fuel level versus understeer, lap time, tire temps, roll angles. You would probably learn a lot and be better set up. You would know, not guess, what the fuel level does to the car.
#35
Basic Site Sponsor
Basic Site Sponsor
Received 3,307 Likes
Another basic analysis (which guides sensor choice) perspective from Vaughan (924RACR).
Here's a good PPT that he made up almost eight years ago. Lots of good info. http://www.vaughanscott.com/Tech/Dat...ysis_Intro.pps
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#36
Basic Site Sponsor
Basic Site Sponsor
For oil, fuel, and coolant pressure, you can use the KA sensors that AiM sells. They are much nicer than the VDO senders and are true motorsport quality.
Now, for how to tap, there are lots of options. For coolant temps, you can see if there is a spot on the engine to put the sensor in or you can put one of these in a coolant line.http://www.amazon.com/Mishimoto-MMWH...W5TN5DTDFWEZ2H There are a ton of people that sell similar taps for the coolant lines.
I used to sell rotary pots for TPS and belt drive rotary pot kits for steering angle, but when I discovered that for 90% of the installations that the slightly greater cost of the string pot was MUCH more than offset by FAR less time and effort to install, all I recommend and sell now is the string pot for those two applications.
#37
Rennlist Hoonigan
GREAT summary, Matt!
String pots are really great for their ease of installation.
#38
Thanks Peter!
I get what you're saying 'bout light/dash positioning etc; we have the same issue in our 924 with an AIM dash, and so added more lights positioned as we wanted to deal with the extra stuff (only oil pressure in that case). The prototype (in my avatar) is even worse; there's probably less than half a square foot of dash, total, to put ALL of my gauges, lights etc in. Switches too. Can't even fit most data dashes in the car! It's also blindingly fast, pardon the pun, and on a short course I never have time to even look at the dash. So the whole car is driven off of idiot lights while I try to keep it off the walls...
Red are oil pressure, orange is coolant, and the "E" is actually gear indicator (sequential box)... sadly, that LCD dash is pretty much illegible at speed/in the sun...
Here's the warning light; $25 with sender:
http://www.longacreracing.com/produc...ing+Light+Kit+
Hope that helps...
Hope that helps...
#39
#40
Basic Site Sponsor
Basic Site Sponsor
Yes.
2 bar (~29.4 psi) for coolant pressure.
#41
Rennlist Hoonigan
Correct Toby. All of those adapters are about the same, it's really just picking one that works in the size water line you want to run.
2 Bar is plenty for the pressure. The pressure will run under whatever the pressure the cap is. Most cars it's under 10 pounds.
#42
As an additional data point..
I Have run aim pressure and temp sensors for coolant. Ran alarms on them as you mention.
Same with oil pressure and temp. I have some adapters we had machined to allow for dual 1/8" NPT ports off a single 1/4" NPT port on the engine. I think we used the AiM in line coolant adapters like the pegasus link.
All worked great. We have MoTeC in the GTS/e0 car, but same sensor config we ran in porches, spec e30's, SPB and a dozen or more customer cars.
I recommend removing any analog gauges and using the AiM or Motec sensors when you can because while you can use regular analog sensors, at the end of the day the additional wiring/harness work and potential for problems is greater. kISS is the name of the game with harness work. Harness labor easily exceeds costs of sensors, so keep it simple.
