AIM MXL Custom Sensor Info for older 911
Installing an MXL into 3.2l 911. I plan to remove the analog oil temp and pressure gauges and just use the MXL. I was wondering if anyone had the data/values used to build custom sensor to save some time on the install? Thanks Bob
Rennlist Hoonigan
which cost no drachmas
Most of the senders for gauges are resistance based, so you'll have to put in a pull up resistor and calculate the mV values. I've never tried just using the old senders, so I can't help with the sender calibrations.
Basic Site Sponsor
Basic Site Sponsor
Received 3,219 Likes
It's so critical, in my opinion, to use the AiM sensors when removing the instruments and relying fully on the display for engine health. For that reason, I don't recommend building custom sensors for that using the stock sensors. The best solid state pressure sensors are $159 and the temp sensors are only $45, then use he pull down menus to load the values without issue.
I'm aware what needs to be done, just thought if maybe people shared would save time on install. I only have 2 weeks till race and with Holidays I have no time. Still have a lot to do installing lights, radios, brake systems, and such. Installing new shiny sensors then running cables thru the tunnel to the dash (plus $40 each sensor for patch cables) is not a critical path item. So would have $300 invested, too much time and then what? The analog sensors were fine. Just want to capture readout on dash. The factory wires are sitting in the dash location. Isn't that what this thing is supposed to do?
Basic Site Sponsor
Basic Site Sponsor
Yes, it should do that after installation of a pull up resistor and calculating the mV values. Just don't have the values from the stock sensors. Sorry.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Yes exactly. That is why I was asking the board to share knowledge and help a Rennlister save time. Just like getting the factory plastic gas tank readout from Cupcar onto Aim Dash in Gallons remaining. I did this and shared data with numerous folks doing same to save them time and effort. If all you AIM guys got together I'm sure you could come up with a nice little spot in Rennlist for storing data like this for easy reference for future customers. Just a thought.
Bob, I think the factory oil pressure sensor on the SC is a VDO 0-5bar pressure sensor. If I recall, that is one of the standard sensors defined by AiM. I can check my factory manuals for oil temp readouts to see if they provided ohm ranges that correspond to select temperature values. Let me know and I will dig in and see if I can find the values. Oil pressure and oil temp and fuel and you are done!
Basic Site Sponsor
Basic Site Sponsor
If that VDO 0-5 bar pressure sender is correct, AiM sells a harness that has the right terminals for the sender WITH a built-in resistor and a 719 plastic connector (for the cheaper $29 cable) to the MXL-MXL2-MXG. Will save you some time!
Rennlist Hoonigan
I don't have any of the values (like Peter) because I always advocate using the AiM dash instead of the factory gauges. The senders that AiM uses are motorsport quality and miles better than the VDO senders. With the temp senders so cheap and only needing a couple of pressure senders, I've never messed with the factory senders.
Fuel for short term will still be using factory gauge. Factory VDO in the SC was the single wire sender. The VDO is a 2 wire. This seemed so easy went I went down this path. Oh yeah and the 20 other major things to do as well as some cage work. Oh well.
Peter this is exactly what i am trying to do before my car goes to sebring from pa. first week in jan.. need connections from stock sensore ( or aftermarket if you have for: oil temp, oil pressure, and oil presure idiot light ) fir my 3.2 l... would like it to be reasonably plug and play, and set it up such that oil press and temp can be logged also. cheers frank
Rennlist Hoonigan
