Strip + Cage My 996 GT3 or Trade for 997 Grand-Am?
#63
6GT3 Cage
Are you planning to install a "knee bar" to connect the A pillars? I caged a 6GT3 exactly like yours and absolutely LOVED racing that car. I crashed hard at Road Atlanta. Had I to do it over again I would have added that A pillar to A pillar cross member and gone through the dash to the front suspension pick-up points, connecting also those L to R under the trunk (same as the 2002-2003 GT3RS race cars). IMHO, this would have saved my J car from being scrapped.
FWIW, I went to a GS car after the GT3 demise and then bought a 996 Cup.....the best car decision I have ever made.
just my 01 cents worth. Good luck, looks like a great build and you will have a BLAST racing/DE-ing it.
#64
Looking good Francois! Christmas came early for you.
#65
I have not cut up the car or made anything irreversible so far in the build, save for a few drilled holes for mounting the cage and stuff. I started the project wanting to be able to go back to "street car" in the future but, to be honest, I don't think that that's going to happen, so maybe in a next phase I might go further, to a custom welded cage.
Will be racing in stock/prepared class and, per the rules, the cage must "remain within the passenger compartment" so going to the front suspension pick-up points is not an option.
Yes Dave, Christmas came early in the form of a project that is keeping me busy, read not-bored, and that is teaching me a lot about these fine cars of ours. I have to force myself to go to bed at night otherwise I would just keep going. Went til 02:00 on Friday night.
Sorry to those who subscribed to the original thread as this is turning into a build thread, cause
#66
Hi, you may want to move the transponder more forward, most forward postion wins, also should have a clear shot to the ground , best signal pick for track to pick up. Custom Cage , most certainly .
#67
Know anyone that builds cages
I was going to ask you to modify the door bars so that I wouldn't have to cut up my own doors before I found these two Boxster doors.
Rough cut (I might even be able to use the stock Boxster inside handles)
#70
Thanks Stu, my friends are on my case to do the Sebring 48 Hours, but I don't think that that's going to happen. Realistically, goal is Monticello in May.
#72
It doesn't work like a lap timer that triggers outward. The race transponder at start/finish sends a signal across the surface of the track. Your transponder needs clear air underneath to trigger that signal.
#73
I will relocate it but now have 4 extra holes in the tub, sheesh.
