Ims beware
I don't have an issue with the vendor. Yes it was Pedros Fix NOT the LN Solution.
I unhooked the oil feed line to the bearing and blocked it off. Restarted the motor and let it run. The lifter noise went away and the cam timing was back to normal. I can only speculate as to why it was doing this only on the one bank where the oil was being diverted to the ims bearing and not to the cams and lifters. I don't believe that taking oil from this point in the engine is a good idea, you can starve critical engine components and cause a failure. This is the first time I have seen Pedros fix so I have nothing to compare it to but I have installed many of the LN solutions and not had a single problem with any of them.
Just watched Pedros 2nd video, he needed to keep the outer race stationary for that to make any sense. All he is doing is spinning a wheel at high revolutions and of course it will throw the oil everywhere...
