Bedding in new brake pads - impossible?
Old 05-19-2014, 12:23 PM
Juan Lopez
Juan Lopez's Avatar
Yep plus no oxidation issues.
Old 05-19-2014, 10:57 PM
996tnz
996tnz's Avatar
Originally Posted by JRitt@essex
It's possible on the street without breaking the law, but you have to condense the process.
Here's a video I did on bedding in brakes. In the video I never go above 60 mph, and I'm able to get a nice pad transfer layer. The higher the temperature threshold of the pad, the more heat you have to pour into them to get them to stick to the disc face.
The idea when doing the bed-in at lower speeds is to condense the entire process and make sure the brakes are cooling down as little as possible between stops. In most cases, people don't get their brakes hot enough during the process. They start to smell the pads or see a little smoke, potentially freak out, and quit.
Going faster just makes the process quicker. A stop from 110mph down to 30mph is changing far more kinetic energy to heat vs. a stop from 60mph down to 30mph. You can still ramp the heat up enough with stops from 60mph, but you'll just need more cycles with less time between. Hopefully that makes sense.
I did this too. Calculating the lower speed ranges is slightly tricky as kinetic energy is proportional to the square of the speed (ie 100-50 uses twice as much energy as 50 - 0 in a vacuum), but there is less air rush cooling the pads at lower speeds, so the ratio might be 1.8 to 1 or so.
Can't remember what I worked out exactly but on an empty section of freeway my first attempt still didn't get them hot enough to whiten the yellows, so I did it again. Keeping a close eye on the speedo while basically riding a rollercoaster left me the most car sick I've been since I was a kid BTW (and I have no problem with Autocross, skidpans, track etc). It did the job though the second time around. The Pagid RS 19/29 yellows are endurance pads and I think you'd want to either have a very tight track or be on it by yourself if hoping to bed them in properly there.
Old 05-19-2014, 11:27 PM
JayinToronto
JayinToronto's Avatar
Thanks everyone!
Man I love this forum. The wide range of answers, from technical to anecdotal to video to alternative product to humorous was exactly what I needed. I'm going to give it a shot on one of the highways keeping the principles learned here in mind. I'll let you all know how it goes!
Old 05-20-2014, 03:30 PM
JRitt@essex
Basic Sponsor
JRitt@essex's Avatar
Originally Posted by 996tnz
I did this too. Calculating the lower speed ranges is slightly tricky as kinetic energy is proportional to the square of the speed (ie 100-50 uses twice as much energy as 50 - 0 in a vacuum), but there is less air rush cooling the the pads at lower speeds, so the ratio might be 1.8 to 1 or so.
Can't remember what I worked out exactly but on an empty section of freeway my first attempt still didn't get them hot enough to whiten the yellows, so I did it again. Keeping a close eye on the speedo while basically riding a rollercoaster left the most car sick I've been since I was a kid BTW (and I have no problem with Autocross, skidpans, track etc). It did the job though the second time around. The Pagid RS 19/29 yellows are endurance pads and I think you'd want to either have a very tight track or be on it by yourself if hoping to bed them in properly there.
Yes, correct on the speed issue. The obvious solution is that your car needs more power so you can get back up to speed more quickly! Well, at least you can use that argument to try and convince the wife....my new turbo's are purely for safety reasons honey!
Seriously though, getting the job done in my Z06 is far, far easier than it is in my Miata! You're almost instantly back to 60mph vs. eating a sandwich while slowly creeping back to speed after braking.
Thanks everyone!
Good luck and be safe.
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Old 06-16-2023, 04:34 PM
Luxdecor
2nd Gear
Luxdecor's Avatar
I found best bed sheet on this website: https://luxdecorcollection.com/collections/bed-sheets
We are excited to this offer customers a wide variety of high-quality bedding collections. This goal is to provide you with the perfect combination of style, comfort, and durability.
You'll love this bedding collection! These is top products, including bed sheets, fitted sheets, bed skirts, blankets, pillows, pillow covers, mattress toppers, duvet covers, quilts, and comforters.
Old 06-16-2023, 04:35 PM
Mike Roblin
Mike Roblin's Avatar
^ lololololol 😂
Old 06-16-2023, 06:28 PM
Nickshu
Nickshu's Avatar
One reason I love PFCs. No bedding. Just put them in and go race.
Old 06-16-2023, 06:45 PM
zip465
zip465's Avatar
Or... just have the rotors a pads machine bedded - https://prosystembrakes.com/bedding/
Old 06-16-2023, 09:45 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Received 3,293 Likes on 1,873 Posts
Originally Posted by dan212
The basic idea is to get some real heat in them. Some hard braking as best as you can (you don't need to come to a stop), and then some lighter applications followed by cool down..
The main things is to get a stink from the brakes, and then you can do the lighter applications and cool down.
You won't hurt them. If you do it right they are bedded in. If you don't they just aren't bedded in enough. If this is a street car and you find the brakes squealing after a while one or two hard brake applications will do the trick.. Really the same principal.
+1,000!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 06-16-2023, 09:48 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Am I the only one that noticed this is a 9 year old thread that was bumped by spam?
stownsen914 (06-17-2023)
Old 06-16-2023, 10:11 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Killjoy!
Old 06-16-2023, 10:29 PM
Nowanker
Nowanker's Avatar
Location: Formerly the DPRK, now seeking political asylum in Oregon
I think Mike Roblin actually beat you to that by a little bit.
"You'll love this bedding collection! These is top products..."
Damn. I gots to get me some!
Maybe it'll help me with my brakes.
ProCoach (06-16-2023)
Old 06-17-2023, 12:59 AM
JayinToronto
OP here, I was surprised to get an email notifying me of a response to this thread. Hilarious it was a bot who kicked things off again. Unfortunately I don't need new sheets.
The following 2 users liked this post by JayinToronto:
911therapy (06-17-2023), LZRD GRN (06-17-2023)
Old 06-17-2023, 08:49 AM
stownsen914
stownsen914's Avatar
A good night's sleep could in bedding your new brake pads, I totally get the relevance. Somebody give Luxdecor a medal!
Nowanker (06-17-2023)
Old 06-17-2023, 11:24 AM
Coochas
Coochas's Avatar
Do PFC or Pagid offer Egyptian cotton high thread count pads?
The following 2 users liked this post by Coochas:
KNSBrakes (06-19-2023), RennPart (06-19-2023)
Quick Reply: Bedding in new brake pads - impossible?
