AiM question
If the driver is really interested in improving lap times, I'd recommend the forecast lap not the static lap. If your on a good lap it can provide the incentive to pick up the pace and get it done. If he (she) only looks at the lap once a lap it is much harder to determine what is working and what is not.
Rennlist Hoonigan
which cost no drachmas
That track width is like you thought - it's creates a sort of imaginary line at the exact GPS point you enter as start finish. If you had a track that doubles back on itself, like many go kart tracks, you won't trip start finish when on a different part of the track.
Basic Site Sponsor
Basic Site Sponsor
Received 3,273 Likes
I like +/- even more than predicted lap. No more computations in your head are needed.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Cetom
I never use the segments in the config. This was when you had multiple physical beacons. These days, using GPS, you can set segments in the GPS manager software.
You are correct about the box on the right. It is to give a width of the track so the GPS "beacon" will be picked up. When the GPS beacon is selected, these boxes are highlighted. I pick the bottom one and put in 45. I might even use a bigger number at Daytona because the track is so wide at start/finish.
Fantastic , and thank you . it's really kindof cool . at sebring i used gps manager to construct the track . intuitively i had the" car" tick box checked . but with that i was getting no lap times that made sense. so i went to the bottom "specific" box and empirically tried 45 . it worked perfectly. the reason i asked the question was to confirm that the appropriate fix thanks
