Trailer layout - tire rack
Cogito_Ergo_Zoom,
If I ever need a third set of wheels, I will put another rack just like the one I have on the opposite side of the trailer. So far, two sets of wheels have been plenty.....
P.S. My rack is mounted mid trailer and the car clears fine. Only the wing would get in the way....
Be sure to allow yourself room to get in and out of your car. A tire rack directly above your car door could turn you into a contortionist.
Important to bolt or screw into the top rail with the rack's legs or cross bar along with screwing into the vertical steel studs. I lost one end of a loaded rack in a previous trailer which damaged my 6-cup's headlight and fender. I'm now attached with multiple self-tapping #14 screws and haven't had an issue in 4 years of ownership....
I went back and forth and back and forth over this last year. In the end, I didn't want to drill all the way through the walls of my new aluminum trailer.
This works fine. It sort of divides my trailer into two sections at the track which is no big deal... I don't usually need to walk all the way through it.
Cogito_Ergo_Zoom,
Trailer is in storage and I don't have any pics but I use a pair of 4' fold up aluminum racks that are mounted one on top of the other on the left side of a 24' trailer between the front of the car and the "L" part of the lower cabinets. I used beefier bolts than what came with the racks and made what I feel is an important modification. I cut a piece of 1/2" metal conduit the height of the bottom of the top rack front piece and drilled a single hole directly in the middle of the bottom so the conduit would fit in it. In the bottom rack I drilled straight through it so the conduit would go through to the bottom and to the floor. Each of the fronts have a 1/4" quick release pin through the flat face and the conduit to secure the two pieces. I put a rubber table leg glider on the bottom of the conduit to keep it from marring up the floor. This basically adds a leg to the front of the racks and eliminates the rotational downward forces that want to pull the loaded racks off the wall. To fold up the racks I just remove the pins and pull the conduit out of the holes. The bottom rack is high enough off of the floor that I can fit storage tubs and coolers underneath. It's a fairly efficient use of space.
I've been hoping to find a tire rack on large casters that I could roll out of the trailer. Anyone seen or use something like this? Figured i could use the winch to roll in/out. I would store outside at the track, freeing up room in the trailer.
While I have one up front on the left side of the trailer that holds 4 tires, I built this tire cart this fall so I can put more weight on the back end of the trailer and just role them in and out. dizzyj I think this is what you are looking for.
i do it a little differently . i built my tire rack on the floor of the trailer. that way i dont have to lift them . just sort of roll them . then there is a shelf above the tires so i can store other things in bins or do work . the rack is in the front of the trailer and i built a door in the front of the trailer so i can access the tires either form inside the trailer or from the outside
not for everybody but it sure makes things easy .
This is a pretty interesting rig. Full height and only 1 ft longer than a trailex enclosed. Custom built Cargo Pro / Thule designed to hold a cup car and fit inside the owner's garage (total length from the ball receiver to the taillights is 22' 9", with a box just under 17' + the V). Rack holds 7 cup car wheels, and then he used the trailer spare mount for the 8th wheel (mounted two spares on the wall on the rear of the trailer). Pretty smart design and towable by a cayenne (weighs 2,300 lbs empty). the rack was installed during trailer construction.
Thanks for all the ideas, really appreciate it. Much to my surprise, I have yet to find a trailer with a tire rack. Then again, I have not found very many used aluminum trailers....
