Rick's Cayman S track car build
#46
Rick,
thanks for starting this thread. I'm nearing the end of my cayman pdk track build by Chris Smith Racing.
I also chose the Cayman Interseries Stoptech brakes. Jack Baldwin seems to be a fan. I would like to hear more details on the issues with these kits. I ran them at my first shakedown at Road atlanta with PFC 08F/06R, gt3 brake booster and GT3 master cylinder. Brakes felt great, did not overheat, but we did encounter some random PSM failures which seemed to be related to overwhleming the abs.
#49
Jcastle:
Any more info on the psm failure? On my build we are wiring a TC or PSM off switch into the system. I have heard that will kill sport plus so looking into that.
#53
Jenks12M,
Details of my PDK build with Chris Smith Racing.:
- Donor: 2009 PDK Cayman S w/ 72k highway miles
- 3.8L X51 DFI motor swap
- CSR custom air intake
- RSS pulley kit
- Fabspeed race headers and exhaust
- Works Bell PDK paddle shift kit
- Motec c125 dash (needed to control x51 intake runners)
- CSR PDK cooler
- CSR rear quarter panel air ducts (engine and pdk cooling)
- Strip and cage
- OMP XL hans driver seat, sparco eve 2 passenger seat
- CSR bumper / subframe reinforcement
- GT3 bumper air outlet
- carbon fiber front hood and rear decklid
- Bodymotion carbon front splitter
- Interseries rear wing / uprights
- OS Giken LSD
- new axles, wheel bearings and rebuild rear brake calipers
- JRZ rs pro suspension
- interseries stoptech front brake kit
- interseries custom fab front brake cooling
- GT3 front cooling ducts
- rear naca cooling ducts
- TPC ITC sway bars, drop links, toe links.
- CSR RSR style front forks
- Forgeline GA3R and OZ Racing HLT 18" wheels
- fire suppression system
- electrical kill switch
- Solo DL/ Smartycam HD
- in car communicator
- race radio
- cool suit
Chris Smith Racing (CSR) builds a nice car. Build is 90% complete. Finishing up headers and CF bodywork this week. Still sorting out some issues with paddles, PSM, ABS, and dash warning lights. Will start a build thread for those interested.
- RSS pulley kit
- CSR PDK cooler
- Strip and cage
- OS Giken LSD
- race radio
- cool suit
#54
Rick, most folks ditch the radiator cooling fans for dedicated track cars which provides better unrestricted airflow through the radiators. Upside is better cooling at speed, Downside is that you need to shut down the car when you're sitting still to prevent it from overheating.
#55
Just curious about the suspension. Just the coilovers and sway bars? any LCA, monoball ends?
Jenks12M,
- RSS pulley kit
- CSR PDK cooler
- Strip and cage
- OS Giken LSD
- race radio
- cool suit
- RSS pulley kit
- CSR PDK cooler
- Strip and cage
- OS Giken LSD
- race radio
- cool suit
#56
Jenks12M,
- RSS pulley kit
- CSR PDK cooler
- Strip and cage
- OS Giken LSD
- race radio
- cool suit
- RSS pulley kit
- CSR PDK cooler
- Strip and cage
- OS Giken LSD
- race radio
- cool suit
#58
Indeed you are.
I have had the 3rd radiator in the build spec since day 1.
I'll especially need it when I'm tucked in behind you trying to earn a pass.
#59
If you decide to go racing this car will slide nicely into GTB1 with the better brakes. I switched from "I stock " class last year and it has been a lot of fun with big fields showing up at most events.
#60
We use this configuration with the center radiator and a 3.8l and can run in 100+ temps without overheating - coolant temp stays right about 225F and oil temp runs about 250F. ECT is closer to 215 to 220 on cooler days.
Cheers,
