Can you unhook a trailer for a car on it?
its only a problem at the track... when people stand on your trailer to see the race.
but, chock the tires front / back and throw a jack stand in front and back for peace of mind.
just in case someone jumps up to look at the car while you're away
Yada, yada...all of the above...
In addition, I would have a "Denver Boot" on the trailer, and one on the car. I'd also have a trailer ball lock.
Thieves just love to steal racecars off unattended trailers.
If you are really paranoid, have Lojack installed on the race car.
Denver Boot? Maybe not!
Whoops, the bit about the "Denver Boot" may be bad advice, see: http://cyber.eserver.org/das_boot.txt
I had to leave my trailer for the day, had some business to attend to. I took the trailer to a Porsche Independent shop and asked permission to leave it there for a day..they were OK with this.
Too many creeps out there these days. I have jacks on all four corners of my trailer. If a wave of paranoia were to wash over me, I could jack the trailer up and remove all four trailer wheels, put the wheels and lug nuts in my trailer bed, or cab if you have extended cab. Lojack on the race car would be nice too.
You can use the tongue jack on the trailer to raise the front and put a reasonable amount of pressure on the jackstands.
And as already mentioned, if the trailer is properly balanced, you should be able to raise the tongue above the hitch ball without any problem. If it starts tipping before that, you need to adjust the car's position on the trailer, or add more weight up front, like tires, toolbox, fuel jugs, etc. If there's any concern at all, you may want to consider moving the car forward on the trailer just as a precaution.
As a rule of thumb, I tend to consider where the weight balance midpoint is on the car, and then try to position that slightly ahead of the trailer axle(s) mid-point. Its a good starting point; a tongue weight scale can help you fine tune. A properly balance trailer also tows much nicer.
You want approximately 10-12% of the gross trailer weight to be over the tongue when the trailer is level.
3000# Trailer
2800# Car
500# Gear
6300# total = 630-756 pounds measured at the tongue.
This measurement should be done when the trailer is loaded as you would head to the track. Most trailer parts/repair shops have tongue scales and will check it for a small fee or free in my area.
Anyway, when your trailer is properly set up, you can disconnect it from the tow vehicle fully loaded with no issue and you don't need jack stands - Just very good chocks.
3000# Trailer
2800# Car
500# Gear
On temporary vacation
Just remove the steering wheel from the car and the kill switch to off. It would take some more than an opportunist to take it.
