Harness shoulder belt advice needed
I just bought a Sparco 6 point harness for my 911. It came with snap in hardware(eye bolts). My previous harness used a 3 bar slide wrap for the shoulder belts wrapping around the cage harness bar. What I need advise on is it looks like the Hans shoulder belt would like to be mounted centerline in the car to get some angle on the belts( 20 degrees ?). Anchoring the shoulder belts at the rear seat belt mounting points and going over the harness bar crossing the belts seems to be OK. What do you think and thanks in advance for the advice.
Not an expert, but have been researching this and plan to install Schroth 6 pts in my Cayman. Can you just unthread the clips and then wrap the shoulder harness to the bar? Schroth website has detailed instructions on geometry etc. They recommend the straps be as short as possible and don't recommend the rear seat anchor points as it leaves the straps long and they will stretch more in an impact. If the roll/harness bar is more than 500mm (20in) from the seat then the straps should be crossed. I plan to use split collars to keep the straps at the correct angle. Hope that helps.
Glad it helped. Yes Schroth has quality stuff though a little pricey. I got their GT3 specific harness since I have the sport bucket seats. Have to say setting up is more complex than I first thought.
Remember when mounting the shoulder belts that HANS recommends only a 3-4" gap between the shoulder belts when wrapped around a harness bar.
Also remember that the longer the belt is the more it will stretch - ie the closer you will come to hitting something when the belts are placed are placed under duress. I think the common approach is to wrap straight to the harness bar and keep the belts as short as possible. Not sure why you can't recycle the the 3-bars from your old harnesses. I don't think they have a shelf life.
