BEST hub/quick release for Momo wheel
GT3 player par excellence
like i said, just get rothsport. it's just money.
you know how tall i am and how tall chasen is.
we have same car as you, chasen and i bouth run momo adaptor, rothsport QR and either momo 07 or omp superturismo wheel.
The Penguin King
Rothsport! OK, actually responding regarding the hub. For a 997 I found you need a short boss hub. I installed the momo adapter and the steering wheel was practically in my lap. Change to a NRG and works great. You will need to trim a a bit of plastic on the clockspring if you want to retain it.
I wanted the boxster cockpit set up exactly like the cup, I like the factory cup QR with the tapered slot, the easiest alignment and no play. Rennline makes a QR with the same configuration/dimensions, and has the same quality as Rothsport. Don't know how price compares iirc about $325....don't think you can go wrong either way.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I went with a PMNA OEM Cup steering wheel and quick disconnect.
Great unit.
Rothsport users -
Horn still functional? Without cords wrapped around steering column?
Works bell ftw if you street drive at all
rethsport no horn, u have to wrap coil wire, unlike bell
I have pmna QR and momo and Rothsport. I use Rothsport on all my trk car now.
