Shift tower riser
Old 02-16-2015, 02:41 AM
Function-First
Basic Sponsor
Function-First's Avatar
I haven't created a product page for them yet, but I will be offering the shifter and E-brake risers from the 996 Console Riser Kit separately, for those of you running without the interior.
If you raise the shifter and want to keep the E-brake, you'll have to raise the E-brake to provide a clear path for the shifter cables.
Spinout, if you're interested in just the E-brake spacers, shoot me a PM.
Shifter is spaced up 2"
E-brake is spaced up 1.5" (to clear the driver's shifting arm)
Comprehensive Shifting Solutions for your Porsche.
Old 02-16-2015, 07:35 PM
dgmark
dgmark's Avatar
I just installed this unit in my 996. I have not used it. but will soon.
Old 02-17-2015, 09:39 AM
Spinout
Spinout's Avatar
That's the one I have although I'm running a numeric shifter. Would you please post a pic of your shifter cable routing at the Ebrake assembly (assuming you have one) ?
Old 02-17-2015, 11:01 AM
dgmark
dgmark's Avatar
Sorry no emergency brake, It is realy only made for a console delete. The cables should run under the e-brake handle with some risers
Old 02-17-2015, 11:05 AM
Spinout
Spinout's Avatar
^^. Thanks. That's what I wanted to see. If I can't route the cables under w a riser or over the assembly, I suppose I'll loose the EBrake and be done with it.
Old 02-19-2015, 11:44 AM
ir_fuel
ir_fuel's Avatar
Does it require more than simply removing the shifter, installing the riser and putting it back on? Is there adjustment work needed on the cables?
Old 02-19-2015, 11:56 AM
Function-First
Basic Sponsor
No adjustment within the shifter mechanism is necessary.
Old 02-19-2015, 03:39 PM
spg993tt
spg993tt's Avatar
You'd have to double check this, but the angled risers are more preferrable than the cheaper flat-top risers. those flat top risers but , if i recall, undue stress on the shifter cables and connectors.
on the last machine we built, we went with the rennline riser which was fantastic, but then also went with the numeric cables and housing, and connectors which really was awesome, super smooth action, and everything looked bullet proof. granted, i havent personally broken a shifter cable or had too many issues with connectors, but that numeric stuff looks bomb proof.
Quick Reply: Shift tower riser
