Can someone point me in the right direction to find the rubber material guys use to tie the shoulder belts to the roll cage, thus keeping them up and accessible when belting in? Seen several cars set up with this- looks simple and effective.
^ Scott, it's just nice to avoid sitting on your left shoulder belt and/or have to reach around to grab 'em. Makes in and out just a wee bit easier. Wait, that sounds bad.
At some point after I get out the car, I come back to it and loosen the belts as required. I drape the lap belts over the sides and I drape the shoulder belts over the ears of the halo seat. When I climb in, all the belts are easy to get to...
Scott
And then I climb in and my fat *** drags one or the other lap belt into the seat where is firmly lodged between said *** and said seat. With the tubing this doesn't happen.
Scott
I get it. Try the tubing. One less thing to worry about. Unless you have incurable OCD.
Scott
That's what I'm doing, but I saw this and it looked pretty easy. Plus I would guess you don't have to worry about a twisted shoulder belt.
