996 Splitter from Joe T. - a review
In the various 996 sections there are a number of threads about the fiberglass splitter that member Joe T. produces. It extends further than the Cup car splitter so I thought I would give it a try and ordered a pair (these things are disposable on a race car!)
First, the fit is perfect. It installs just as easily as the factory piece without any unusual gaps. Only concern is that it is inflexible unlike the plastic factory piece. Not sure what will happen if it impacts a curb or I do some farm work. Will it crack? Will it sacrifice itself and fall off? Or will it remove my front bumper? I have no intention of trying to find the answer, but realize that one day I will.
On track results - wonderful! I ran a single session at MSR yesterday and there is a material difference on front end grip. In particular, in Ricochet and Big Bend (the fast stuff) I was able to rotate quicker on entry and get to full throttle quickly without fear of washing out beyond the track's edge. I have not looked at data but noticed my shift points came quicker on the straight. AJ from PST was standing on the pit wall during the session and also told me he noticed I was flying through the entry of Rattlesnake as well (slow corner), he could tell I was on it!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Net result, I ran a 1:18.7 in my NASA GTS4 car on 8 cycle Michelins that first ran at TWS March of last year and while carrying a full tank of gas. If I slapped on stickers and emptied the tank, I am certain I would have found the 1:17s, something I have not done before.
Looking forward to the dive planes he is developing ....
Did not take any pics but it does not extend past the bumper. Looks to be perfectly even with it.
I'm running the Cup wing and uprights, but I am about to switch to a set of roof height uprights.
Looking to get that done along with adding the cup rear wing. I am wondering if I will need more front end downforce though or if just doing the radiator tilt will be sufficient.
Thanks. I want to run this splitter on my car, but want to balance it out with an RS wing. I don't have the upper radiator vents (RS-style vents), so even with this splitter I won't have as much front downforce as you, and hopefully won't need a cup wing. A fellow in the 996GT3 forum mentioned that this splitter works well with a stock wing at 8 degrees, but I'd rather run an RS wing with less angle.
Yes, I've got the vents and titled radiator.
On the track, I've tested the car with no splitter (it fell off during a race), street splitter, cup splitter, and now this one and each step showed a noticeable improvement. We have a particular turn on our home track (Ricochet) that really amplifies the effect when the turn is taken at speed and its amazing what even a little change to the front end can do here. Keep in mind this is being done to a race car where the car is already tuned to be rather sensitive to changes, YMMV on a street car.
