FS: 964 H class Race Car
This H class race car only has 2 races on it since completion. Must sell due to buying another car. Comes complete with log book and 3 sets of tires with Fikse rims. Very competitive in H class. Many years of race history with podiums in both F and H class. please contact me at Washin8@aol.com.
1990 964 build sheet
Interior:
Safety Devise full cage
Interior gutted and painted w/all sound deadening removed
sunroof delete
doors gutted
custom switch console
shift light
race peddles
fabcar shifter and linkage & precision couplers
s.p.a fire suppression system w/external and driver button
emergency shut off
kirkey drivers seat w/ brey krause seat brace
fiberglass passenger seat
five pt. harnesses
rs door panels
window net
ballast box
aluminum floor boards
Exterior and chassis: aprox 10 hrs on bearings bushings and brakes
RS mirrors
3.8 tail
custom adj. splitter
oil cooler ducts in bumper cover
mono ball suspension with adj. camber plates
H&R bilstein cup suspension professionally tuned
adj sway bars w adj drop links
steering wheel quick connect
adj camber plates
stainless steel brake lines
big red front brakes w/ 2 piece rotors
turbo rear brakes
performance friction break pads
front brake cooling kit through front bumper
steering rack stiffening kit
corner balance and track align.
brey krause strut brace
cool suite
Engine: approx 10 hrs on rebuild
3,6 block
new mahle pistons and cylinders and rings
carrillo rods
ARP rod bolts
new main bearings and pin bearings cut fitted for rods
fresh 3.6 heads w race springs and seats
Evolution motorsports cold air intake
stainless headers w/heat boxes
2 into 1 custom pipe
rs pulley delete
fresh distributor belt w/vent tube
fresh alternator
tilton ot2 clutch and flywheel
internal puck clutch slave w/ steel braided lines
ECU chipped and flashed for tilton clutch set up
race axles
european ring and pinion transmission
rennline solid motor and trans mounts w/gusseted motor mount
new oil lines and dual oil coolers
FRESH FULL PAINT JOB
$33000.00
Interior:
sunroof delete
doors gutted
shift light
race peddles
emergency shut off
five pt. harnesses
rs door panels
window net
ballast box
RS mirrors
3.8 tail
adj camber plates
turbo rear brakes
cool suite
3,6 block
carrillo rods
ARP rod bolts
rs pulley delete
fresh alternator
race axles
$33000.00
