Prep Time
Prep Time
What do you do to get your car ready for track day?
Thanks Jim ~ appreciate the advice ~ will need all of it that I can get
968 Race car maintenance between races:
Prep for Road America in October
Check oil
Check radiator water level
clean-out radiator if necessary
check pwr steering fluid level
bleed brakes
check brake pads Just changed at Grattan to CL6E
nut and bolt front end
check wheel bearings
Check shock nitrogen settings
check front shock settings
check cv joint bolts
check TA fluid level
check rear shock settings
nut and bolt rear
down load data from AIM
down load video and erase
c/u inside of the car
c/u outside of the car
Clean rubber and debris from inside of rotors
Additional for October 2012
Re-Install air shroud cover
clean and oil airfilter
Check toe setting and set it for <1/8 th
Change TA oil
Get front end reattached
Change spark plugs
Mount practice tires
Check oil
bleed brakes
nut and bolt rear
Change TA oil
Change spark plugs
Wax the daylights out of it--it'll make it easier to remove all the oil/rubber marks/etc. you'll pick up. To remove all that stuff when you're done, wash and wax again.
Gary
Gary
Sounds like a need a full-time mechanic or a hoist
