F-Class 911
8th Gear
1986 Factory Turbo Look Coupe (Option 491)
Porsche Certificate of Authenticity
Purchased at 36K miles for $30,500.
Currently has aprx 42K miles
Chassis
Suspension corner balance and set up by Grand Am crew chief, Greg Jones (set-up sheet available)
Smart Racing Products Front and Rear Sway Bars
Smart Racing Products Torsion Bars, Rear 31mm, Front 23mm
Smart Racing Products Camber Front Ball Joints
Smart Racing Products Bump Steer Kit
Smart Racing Products Camber King Strut Brace
Smart Racing Products Front Mono-*****
Elephant Racing Poly-Bronze Rear Torsion Bar Bushings with grease fittings
Elephant Racing Adjustable rear swing plates
Elephant Racing Front A Arm Alignment Bushing
Elephant Racing Front Poly Bronze torsion bar bushings with grease fittings
The Racers Group Rear Swing Arm Mono-*****
The Racers Group Rear Top Shock Mono-*****
Racers Edge, Leda 24 Position Double Adjustable Remote Reservoir shocks rear
Racers Edge, Leda 24 Position Double Adjustable Remote Reservoir struts front
Turbo Brakes with stainless steel lines and drilled rotors – factory installed
Smart Racing Products Front Brake Duct Housing and Stainless air deflectors in each hub
Optimized Front/Rear Brake Bias
Larger 23mm turbo master cylinder – factory installed
Wheels
2 sets of CCW forged alloy 3 piece race wheels ( shot peened anodized black – shot peened anodized brushed silver)
17X9 Fronts, 245/40
17X11 Rears, 295/30
Drive Train
Autometrics built 915 Transmission at a cost of 11K– matching numbers
• Shortened ratios with steel synchros
• GT Racing 2cd, 3rd, 4th, 5th gears
• Guard transmission race limited slip 50/80 lock up
Patrick Racing Lightweight Flywheel – Installed new one race ago
Smart Racing Products Precision Coupling Linkage
Wevo Short Throw Gear Shift
Wevo Solid Billet transmission mounts
Wevo Semi Solid Motor Mounts
New Front and Rear Outer Wheel Bearings
Engine
Jerry Woods racing Valve springs and retainers
Steve Wong Custom Dyno Tuned Chip – producing 229 Rear Wheel HP- 198 foot pounds of Torque
AEF High Flow Air Box and Power Flow washable filter
Balanced and matched factory fuel injectors install new last year
Smart Racing Products Left and Right block off plated for improved engine cooling
European Equal Length Racing Headers, Jet Hot Ceramic Coated
Custom Stainless Steel Stinger Exhaust
Recent Valve Adjustment
New Head gasket kit
Turbo Valve Cover
B&B High Volume Front Valence Oil Cooler with Stainless Braided Lines
No engine work – all original
Joe Gibbs Racing Oil, XR7 for flat tappet motors
Safety
OG Racing Roll cage – welded in
Window Net
Sparco Circuit FIA Seat and Mounts
Sparco 5 Point Harness – Expired Date
High Density roll bar padding
Smart Racing Products Kill Switch with custom alloy bracket
Interior
Removed and painstakingly painted
RS America Lightweight door panels
Traqmate Data Acquisition GPS – Complete
Motorola Radio and antenna – Push to talk steering wheel button
Sparco Leather Race steering wheel
Smart racing Products removable steering linkage
New steering busing installed
Optimized lead ballast
Exterior
3M Clear protective on all front surfaces
Removable custom graphics
Geddy Racing FRP Front and rear IROC bumpers
Geddy Racing FRP IROC rear spoiler
H4 Headlights
Tow strap in rear
Tow hooks in front
Will have fresh re-spray on front bumper and side rockers
Prep
All allowed deletions for Prepared have been completed – No AC – better center of gravity
The upgrades listed are legal modification for a PCA Prepared F
In 2012 the new rule states this model can lower the weight an additional 123Lbs!
Results
F-Class track record holder at VIR and CMP
2:27s at Sebring
1:38 at Road Atlanta
2:10 at VIR
1:53 At CMP
Podium Finishes in all races for the last 5 years
Price
Fairly Priced at $36,000 with both sets of wheels and trailer
Chassis
Wheels
17X9 Fronts, 245/40
17X11 Rears, 295/30
Drive Train
Engine
New Head gasket kit
Turbo Valve Cover
Safety
Window Net
Interior
Exterior
H4 Headlights
Tow strap in rear
Tow hooks in front
Prep
Results
2:27s at Sebring
2:10 at VIR
1:53 At CMP
Price
very nice, with lot's of "go fast" stuff. GLWS
Chassis
Wheels
17X9 Fronts, 245/40
17X11 Rears, 295/30
Drive Train
Engine
New Head gasket kit
Turbo Valve Cover
Safety
Window Net
Interior
Exterior
H4 Headlights
Tow strap in rear
Tow hooks in front
Prep
Results
2:27s at Sebring
2:10 at VIR
1:53 At CMP
Price
Chassis
Wheels
17X9 Fronts, 245/40
17X11 Rears, 295/30
Drive Train
Engine
New Head gasket kit
Turbo Valve Cover
Safety
Window Net
Interior
Exterior
H4 Headlights
Tow strap in rear
Tow hooks in front
Prep
Results
2:27s at Sebring
2:10 at VIR
1:53 At CMP
Price
8th Gear
Lots of interest - yes the gear box is legal, as a prepared car you can run shorter ring and pinion. Creates higher heat therefore put GT racing gears and stainless steal sync for reliability. This car runs up front and routinely get checked post race and passes.
