Car Sickness Racing
Patch,Bonine,Psuedophedrerine? Thoughts?
Happend again at Mid Ohio and a good cure would be worth 2-3 seconds a lap!
You can try to train your brain to accept the disconnect between what you see and what you feel. It may be a very unpleasant training period, but it can be done. Do you get sick in simulators or movies?
Ginger has anecdotal evidence for preventing motion sickness.
go to doctor, it is most likely result of vertigo caused by particles in the liquid in the middle ear area, there is very simple physical therapy procedure to get rid of that but it may be more complicated in some cases. overall you feel sick as brain is confused my mismatch from data you eyes provide when it does not match what your middle ear reports. it got nothing to do with stomach.
i know in my case only repeated procedures helped to reduce it to some level, self mediaction was pretty useless unless you swallow something strong enough to knock out your brain flat but to drive in such condition is not a best idea.
http://medicalartsrehab.com/vertigo-therapy.html
There's an electronic air sickness wrist band that I've used for passengers that get sick on small planes/helicopters you can get it at Sportys pilot shop. Worked well for people that were very nervous about it, solved some issues with boaters wives as well...
Where are you looking when it sets off? If your eyes are up/out you can avoid the problem...may want to move your lap timer so you're not looking down in the cockpit.
Exposure to the stimulus that causes the sickness can help the brain learn to deal with it. The problem is that driving a race car isn't the best place to be trying to induce it.
then they just settle down again and all symptoms are gone.
I had it for awhile also, had every test known to mankind performed, try googling Epley Maneuver, it's a series of moves that repositions the crystals. It helps to know what ear is the issue and the Dix Hallpike will show what ear it is. It really helped me and it is a simple exercise, also try neck exercises as this will also help the stabilization of the head. It took me awhile but problem gone, I do these exercises now as a precaution. Good luck, I know how annoying this is!!!!!
I have delayed motion sickness, especially when I'm instructing. I'm fine most of the day, probably due to the endorphins and adrenaline, but get violently nauseous in the evening - not fun.
Anyway - I've found the scopolamine patch to be very effective. Side effects can include blurred vision and dry mouth, but I cut the patch in half to get a lower dose and the side effects are minimal. Doubles the number of patches too!
I also have found the patch to be the difference when instructing a not so smooth student. I probably would have to stop instructing if not for the patch. The only time I had a problem driving was my first time at Road Atlanta. I figure it was due to the elevation changes.
Mark
Mark
