Tach Wire To Traqmate. Which Wire?
I am adding RMP to my traqmate and I don't know which wire on the tach is the coil wire. Car is the 1979 911 SC (Euro Model)
Can anyone point out which wire or explain how to check continuity? Pix show the back of my tach.
TIA
TIA
I have one with a stripe. Its a little hard to be sure of the color because of age. I looked at the coil to see if a stripped wire came off of it, but no.
Will it hurt the Traqmate or the tach if I connect for a test?
Basic Site Sponsor
Basic Site Sponsor
Received 3,299 Likes
Shouldn't. Set up the Traqmate dash to read RPM, then touch (brush) it to the lead on the back of the tach while the car is running. Tach reading on the TM means you're set.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Thanks, Peter. I don't have the new dash. I have the DU. They don't show RPM. Only on lap analysis can I see RMP. Is there another way to view what the unit is recording? I want to have it working by VIR next week.
Basic Site Sponsor
Basic Site Sponsor
Randy, the Classic DU (the older long, black monochromatic display) DOES display all sensor inputs real time. From page 23 of the 2010 User Manual.
Menu System
All of the Display Unit features are accessible through a text menu system. To access a feature
use the UP and DOWN buttons to highlight the item you want on the screen. Press SELECT to
activate that item. Some items actually perform a function while others go to other menus. This
chart shows the menu tree.
Main Menu
Record Data
Laps – Enters lap timing mode with historical Predictive Lap Timing
Choose Start / Finish – Unit is waiting for driver to choose a Start / Finish
location
Looking for Start / Finish – Unit waiting for vehicle to cross Start / Finish
Erase Start / Finish – Erases Start / Finish for chosen track
Qualifying – Enters lap timing mode with single session Predictive Lap Timing
location
Looking for Start / Finish – Unit is waiting for vehicle to cross Start /
Finish Line
Autocross/Rally – Enters auto-launch mode with separate finish line
Select to Stage – User presses select on starting line
Ready to Launch – Timing starts automatically when vehicle launches
1/8 Mile Car Test
1/4 Mile
Drive – Enters data recording mode with GPS compass and digital clock1
Tach & Speedo – Enters data recording mode with tach and speedometer
onscreen1
Gauges – Enters data recording mode with analog/digital/rpm gauges
onscreen1
G-Forces – Enters data recording mode with G meter onscreen1
Segment Timing – Enters segment timing mode with separate start and finish
Choose Start – Unit is waiting for driver to choose a Start location
Looking for Start – Unit is waiting for vehicle to cross Start Line
Erase Start / Finish – Erases Start & Finish for chosen track
Gs & Location – Enters data recording mode.
Shows x, y G-forces, GPS precision (<250 good), date and time, GPS
location in lat/lon, heading, speed, temperature, and # of satellites in use
(>5 good).
Inputs – Enters data recording mode with analog, digital inputs, and RPM
onscreen
1
Note: ▲(UP) or ▼(DN) cycles through the other screens in any of these modes.
HTH, Peter
Menu System
Main Menu
Record Data
location
location
Finish Line
1/8 Mile Car Test
1/4 Mile
onscreen1
onscreen1
(>5 good).
onscreen
1
HTH, Peter
On this photo the RPM connection is the middle of the three with the Black/Purple showing with the shrink wrap on the connection--
The Blue wire is Traqmate and the green is Shift light.
Regards,
Roy T
Regards,
Roy T
Interestingly, I tapped the blk-purple wire and got no RPM feed. No other wire on the tach sends signal either. I did tap the coil directly and got signal. I guess I will have to get some heat sheilded wire and run from the coil into the cabin where the SU is mounted.
I just can understand why there is no signal at the tach. Any ideas?
Oh, tach is working. Had the car running while tapping each wire on the back. No signal to Traqmate. Coil sends siganl no problem. Go figure.
Peter, you probably have this answer for me.
Orbit is about to re-install the Traqmate again in my new '10 GT3, is there another way to install the antique Traqmate system to pick up RPM without slicing into the wiring harness by the ECU? I had this in my last '10 GT3 and it created many problems, cel, etc
OBD is still wishful thinking?
Basic Site Sponsor
Basic Site Sponsor
To not tap into to the CAN, I think you could adapt an MSD pulse pickup to one of the distributorless coil pack trigger low-tension wires for TM RPM. Part number 8918. Non-invasive.
Info here. http://www.msdignition.com/Products/...MR_Pickup.aspx
Best, Peter
hth,
Dave
Hah! No, but not immediately available. Sometime soon...
Best, Peter
Best, Peter
You're awesome.
Thank you will try it.
