Redneck supercharger
A post in the 993 section got me thinking.... On air-cooled engines, why hasn't anyone tried to pickup higher pressure air from behind the engine fan? Seems like it would be worth a few HP....
For race cars I guess it would be considered a really crappy supercharger so not worth it. Otherwise, what am I missing ??
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Between the fan and heads would be ambient temp, no?
This has really got me interested.... Next time I'm at the dyno I may be bringing some dryer duct and duct tape just to see what happens.... obviously this is not staying on the car, I'm just curious if it will work and if it does.... how well???
Rememeber that you use the heater when it is cold out, and the denser air provides better cooling as well, so the cfm loss then makes no difference.
Well the science of it is that to "supercharge" the inlet air you have to provide positive pressure. One bar is actually a LOT of air when you are drawing it off into the intake. The air cooling is doesn't want to see pressure, that would be a wast of hp, it's designed to optimize air flow/volume. Also why newer cars use clutches on the fan belt. As dumb simple as it looks that peice of plastic is designed with the lower baffles to provide even airflow over each cyl. So if you hook a large vacuum to the air shroud you will quickly outstrip the capacity of the fan and reverse the airflow wherever you connect the tube, most likely drawing air away from one side or worse one cylinder. Run at extended period you could inadvertently overheat the cylinder and actually cause damage. I've seen this with a motor that had a rat make a nest on top of the case and starved number 3.
I did exactly this on my 993 a couple of years ago. I tried to copy the 996 GT3 Cup air intake. I turned the whole plastic air intake manifold 180 degrees, so the throttle body was facing backwards. Then i made a special air box that insulated the air intake from the rest of the engine, with direct air from the (RS) spoiler. I never dynoed this, because you need a certain speed of the car to create overpressure from the spoiler into the air intake. Also, the cooling fan draws a lot of underpressure in the engine compartment, decreasing power, actualle negative (super) charging. By insulating the air intake box from the underpressure in the engine compartment, and at the same time over charge using the downforce pressure from the spoiler, I´m sure that you can gain some "free" HP.
