AIM Solo install in a Cayman S
i tried to use cable first, it did not work. fused power from fuse box is better. i simply took new fuse, wrapped wire around upper pin and inserted it there, works fine. hot pin is a lower one.
Old thread but on topic. I went to wire up my new DL and in my 2009 Cayman S there are multiple twisted pairs that correspond to the CAN+/- line color coding Before I start tapping multiple pairs, has anyone installed in a 2009 and can verify the footwall CAN lines ?
Also, for ground is the bolt that holds the fuse carrier usable or do I need to locate or create a new one?
Cheers,
Mike
Cheers,
Mike
Basic Site Sponsor
Basic Site Sponsor
Received 3,203 Likes
Cheers,
Mike
Cheers,
Mike
If you look at the main harness closer to the rear of the car (or the door hinge area) there is one pair that sticks out.
It's the largest bundle. There is only one pair that matches in that bundle.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
I have personally installed over four dozen of these and have not yet seen that, but there is always a first!
Thanks! That's the kind of luck I've had with this car - from UPS losing one out of four wheels to a stud kit showing up sans lug nuts. I'll grab myself another set of taps and see what happens. Is there any other screen config/setup for additional channels, e.g. oil pressure/temperature I need to figure out?
Basic Site Sponsor
Basic Site Sponsor
To make sure you're getting the right info, go to Menu on the Solo DL, then Display (IIRC), then custom page setup, then on page two or three, select three custom measures like RPM, ECT (water temp) and PPS (accelerator pedal position), then back out, start the car, scroll through to that page using the furthest right hand button and make sure you're getting info. This assumes your Solo DL is configured for the car...
The same (I believe) bundle in my car has two pairs (boxed in red). In your pic it looks like your crossing from the front loom to the back - could just be the pic. Guess it's over to O'Reillys in the AM to get some vampire taps - once I land on the correct pair I can solder 'em up.
Basic Site Sponsor
Basic Site Sponsor
So... In keeping with the car, after tapping the right pair and getting no signal I tapped the left and voila - I've got data. Now to solder everything up and head out to the Ridge.
Basic Site Sponsor
Basic Site Sponsor
Let me know if there is anything I can do to help, I find myself down at The Ridge occasionally when I am not on the road.
