Traqmate: which to buy? complete or dash?
I've been using Traqmate for years and have also used AIM & some others. I recently upgraded to the Traqdash and am blown away at how great it is. I'm now hooked on the "Vmin" display. It's the best driver tool since the predictive lap timer.
I'd be willing to sell my old Traqmate display if anyone's interested.
I think the Solo DL is the best-value, most-conversant-with-the-new-cars black box to come along in years. For the price of the Traqmate Basic, it's a pretty amazing leap forward.
The Solo DL/SmartyCam combo is pretty slick. I made this video with two pieces of equipment and one plug into the OBD-II port installed in about 90 seconds: http://youtu.be/Po4yoytAdDg
I watched the video of the solo DL smarty cam - is that 1800 for everything required? Ie camera data logger bod connector etc?
I'm looking to upgrade from Harry's lap timer soon.
Basic Site Sponsor
Basic Site Sponsor
Received 3,143 Likes
Peter, agree good seeing you and hearing you pour advice into Richard on vmin max equations etc. you really have the track down to a science - love it!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I just bought this- http://gopro.com/hd-hero-accessories...-remote-combo/
It works great. You can buy a second Wifi bacpac solo for your second camera. I cant wait for the phone apps to come out.
Basic Site Sponsor
Basic Site Sponsor
The vMin is the cause and the PLT is the result! No need to wait until you come in and granular enough to evaluate every slower corner, every lap of the session. Priceless.
When I look at the tens of thousands of data files I and other people have collected, the correlation that stands out is that if you can raise the vMin incrememally at each slow corner (and it can be by tenths of a mph), your average will rise much quicker and you'll lop off much more time than trying to go "flat out" through a particular, often short section.
I learned first from the old Stack dash displays and then from David Ferguson at Veracity Data that drivers who configure their displays to read the vMin of the previous corner can evaluate DURING THE SESSION their changes to address that very, very important parameter.
The vMax is a useful aid for determining whether the car is running properly and/or beginning to tune aero for the best compromise between downforce and top speed, but the vMin is the daddy!
The TraqDash just helps you do that easier. Of course, I have them in stock!
Basic Site Sponsor
Basic Site Sponsor
Gregg, I recommend the RAM 1" ball suction cup mount for a Garmin GPS. Works great and you can get arm lengths from 1 7/8" to 3" to 6" long.
I have the traqdash with the Go pro HD video integration. if your going to do this you want the traqdash the display is such a huge upgrade from the old display, if your going to jump off the cliff take a big jump.
As for the cameras, the Go Pro hero 2 is better quality and for the little extra cost you should get the hero 2. I have had both and the set up menu on the hero 2 you can actually figure out with out the instruction book in front of you.
The only issue that i have had is that the trackstudio software that Traqmate has to integrate the video and data has a glitch in it were there is some distortion in the final production. I think this will get worked out.
The only other PITA is that when you record more than 40 min of video on a go pro it splits it into two files and you have to merge them before you can overlay the data, there is instructions on the TM web as to how to do this. its all doable.
Basic Site Sponsor
Basic Site Sponsor
Trick stuff. Especially your TBL in hi-def!
I have the Traqmate and GoPro Hero2 with the interface cable to automatically power on/sync. I dumped my SD Chase Cam setup this year for the GoPro and the video is so much beter plus I use the GoPro for other things like skiing.
The Traqdash is nice, but I see it as a little bling. Also, I don't want a display that big because I need to focus on the driving and not the display. Better to looks at the information after the session at least for my level. The Traqmate is simple and easy to use.
It would seem that something 'straight-on' would be ideal....if all you needed to do was drop your view down.....rather than having to look right or left.
Not the Traqdash, but rather the classic display unit: Stuck a strip of self-adhesive velcro on the bottom of the unit and the mating surface on top of the control column. Not very high-tech, but cheap, easy, and it works. Plus, it's in the line of sight.
